Marshall Jmp-1 Strange Flanger Sound Issue.
Discussion in 'The Workbench' started by mrp, Dec 19, 2016.
Tags:
  1. mrp
    mrp Member
    Dec 19, 2016
    39
    24
    Hi,
    I had been using my JMP-1 for over a decade - stock tubes, OD2 channel - with no issues until recently.
    There was this bad cable that kept producing loud spikes - although I'm not quite sure the JMP-1 wasn't adding up to these as well. After that the JMP-1 started sounding dull, one-dimensional, with poor note definition, and worst of all - with a subtle yet relentless flanger quality to the sound on all four channels.
    Swapping tubes (V1->V2) didn't help at all. Having googled extensively, I assume it's quite an uncommon issue.
    Any help much appreciated.
  2. Len
    Len Well-Known Member
    Sep 13, 2009
    993
    763
    Replace the tubes rather than swapping them.
  3. GT08
    GT08 Active Member
    May 31, 2016
    293
    193
    A bad power tube will cause this symptom.....and take the bias miles off.
    Change the power tubes and re-bias.
    Always keep spare GOOD tubes (power and Pre) for testing purposes.
  4. Jazz P Bass
    Jazz P Bass Active Member
    May 19, 2015
    229
    30
    Wernersville, PA
    That 'Flanger' sound may be your power supply filter capacitors going wonky.
  5. mrp
    mrp Member
    Dec 19, 2016
    39
    24
    Forgot to mention: I use a solid state Peavey KB/A 50 as a power amp with JMP-1's emulator outs. JMP-1's Headphone jack signal has the flanging as well.
    Thanks, perhaps it's something in that vein.
