Marshall JCM800
Discussion in 'Marshall Amps' started by Scott Wurst, Sep 12, 2019.
Tags:
  1. Scott Wurst
    Scott Wurst New Member
    Aug 7, 2018
    11
    13
    Been looking at getting a JCM800. I currently have a DSL40C which I run as a combo or through a 8412 full stack. I can play it on the 20watt setting at home through the stack with volume at about 8 and gain at about 3-4 but don't run it on the 40watt setting. Now onto the 800. What would everyone recommend for gigging small clubs and some outdoor gigs and to use at home in a small studio? Ive heard that the 20watt classics are pretty good but afraid it won't be enough for gigging and the 100watt worried it will be too much for home and studio. Also which would you recommend the 2203, 2204, 2205, or the 2210? Or a reissue 2203? Sucks that there isn't any stores to try them out around here. How about some input on what some of you all are doing. Oh and I play Guns N Roses, Aerosmith, Thin Lizzy AC/DC type tones. Thanks.
  2. MaskingApathy
    MaskingApathy Well-Known Member
    Jan 17, 2017
    230
    273
    Have you considered the 2555x? It will get you the GnR sound easily and can do those other sounds also.
  3. Scott Wurst
    Aug 7, 2018
    11
    13
    No I haven't thought about one of those. Have to look one up and see if there are some comparisons.
  4. Mitchell Pearrow
    9,163
    14,173
    If you are worried that the 20 won’t be enough for outdoor gigs, bring your dsl40c, set up as 2 half stacks, put th 40c on full power green clean, and fx send off of the SC 20 to instrument in on the 40c!
    Cheers Mitch
    MK333, marshalltsl, steveb63 and 3 others like this.
  5. Jethro Rocker
    7,444
    7,882
    Depending on venue, the 20SC is plenty loud.
    MK333 and Mitchell Pearrow like this.
  6. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    1,554
    3,649
    Springfield, Ohio
    Was going to suggest exactly this that Mitch said. Yeah, what Mitch said!
    MK333, steveb63 and Mitchell Pearrow like this.
  7. CoyotesGator
    CoyotesGator Well-Known Member
    Jul 31, 2012
    1,917
    1,701
    The Institute for the Very, Very, Very Nervous
    What component of this are you playing?
    The cleaner parts, or the dirty?
  8. Scott Wurst
    Aug 7, 2018
    11
    13
    Trying to get that dirty crunch sound.
  9. scozz
    scozz Well-Known Member
    Jul 20, 2008
    2,457
    5,406
    Sounds to me like Mitch has the perfect solution, get the SC20 for the studio and indoor gigs, and and use both the SC20 and your Dsl40 for outdoor gigs.
    If you’re playing a lot of outdoor gigs maybe a 2203 would be a better choice. And use your Dsl40 for indoor gigs and studio work.
    Just my :2c:,....
  10. marshallmellowed
    Jun 26, 2009
    3,351
    3,657
    I would think that anyone playing outdoor gigs would be using a PA, in which case, the size (power) of the amp becomes pretty much irrelevant. If this is not the case, then pursuing the purchase of a PA for outdoor gigs might be something to consider.
    MK333, SGFA, SteelLucky and 5 others like this.
  11. Sir Don
    Sir Don Well-Known Member
    Aug 9, 2009
    1,297
    734
    Adelaide, South Australia
  12. stickyfinger
    stickyfinger Active Member
    Nov 11, 2010
    619
    249
    Get the real deal and a attenuator. Small amps never sound big.
    Thank me later.
  13. Jon C
    Jon C Well-Known Member
    May 29, 2017
    1,372
    2,372
    Wa State
    Yay !!! PA !!!
  14. Scott Wurst
    Aug 7, 2018
    11
    13
    Yes Sir Don. That is what I'm thinking.
  15. bad565ss
    bad565ss Well-Known Member
    Apr 5, 2015
    338
    546
    Waterford, Michigan, USA
    I think you'd be good with any of the 2203,2204,2210, or 2205 JCM800 models.
    I've been using my 2204 lately and really enjoying it. I put a mic on one speaker into the P.A. mix that we can set where we want
    and a 4 x 12. They're all sort of different from one another but any of them will do the classic to hard rock thing in exceptional fashion.
    MK333, scozz, Crikey and 1 other person like this.
  16. Crikey
    Crikey Well-Known Member
    Feb 16, 2019
    381
    552
    20 watts wont cut it for outdoor gig. 100 watt 2203 all the way. a 2203 will play medium and large size clubs with good tone at decent volumes. run a patch cord through efrect loop or a eq and youll get that boost and attack without being too loud. IMO
    MK333, Mitchell Pearrow and scozz like this.
  17. ampmadscientist
    15,603
    9,522
    In the old days:
    the PA was for vocals only. The guitar needed to be self-amplified for the whole venue, therefore 100 watt amps 8X12 speakers.
    In the new days:
    The PA carries all the sound including guitars. The amp uses a microphone. The whole stage gets guitar from the monitors.
    Therefore 100 watts could be overkill.
    A big loud guitar amp will bleed into the vocal and drum mics.
    Also a smaller amp cranked way up / mic thru the PA.... sounds better than a big amp turned way down. Covers seats better too.
    So the answer may really be that you need smaller amps, and a good PA system with monitors.
    But if you look at it the other way, JCM800 2203/2204 was the basis for all the modern amps sold today, every manufacturer copied it because it was a ground breaking idea.
    MK333, Mitchell Pearrow and Crikey like this.
  18. Crikey
    Feb 16, 2019
    381
    552
    I'd say 1 out of 10 clubs in the Virgina/North Carolina area has a decent sound system and or sound guy but that maybe even stretching it a bit. I still find that in most clubs even with a soundman that its best to get a good guitar level/ sound and build around it. Micing more of the vocals, bass and kick drum and a bit of snare and hi hat. get the 2203 or 2204 and enjoy. You never need more amp. Bigger places and you get to stretch it out a bit.
    Mitchell Pearrow and bad565ss like this.
  19. scozz
    Jul 20, 2008
    2,457
    5,406
    If you go with a 2303 or a 2204, you could always get an attenuator to use for smaller venues!
    Mitchell Pearrow and Trelwheen like this.
  20. Scott Wurst
    Aug 7, 2018
    11
    13
    Yes I have been taking that into consideration. I agree with you.
