Marshall Jcm 800 4211 Model
Discussion in 'Marshall Amps' started by Crikey, Mar 14, 2019 at 8:50 PM.
  1. Crikey
    Crikey Member
    Feb 16, 2019
    58
    90
    UPDATE, i bought the amp for 500$.tech help needed.
    Its got an issue either in output or preamp tubes. On the boost channel there is very little volume. On the clean channel its loud but not as loud as a 100 watt should sound. How do i diagnose if its tubes or other issue like transformer? All tubes are glowing but drive channel is a whisper. Clean channel seems as if its on volume 3 , volumes are all the way up, when compared to my 900.
    gents, sonically is the 4211 jcm 800 similar tonally with the 2203? I know it sounds like a very dumb question but see one for $850. Thoughts on this model which appears to be a 2x12 combo 100 watt.
    Anyone own or play this model before? I would prefer the 2203 but if its the same guts as a 2203 it seems like a sweet deal
    Anyone? Bueller?
  2. Gutch220
    Gutch220 Active Member
    Feb 19, 2018
    359
    182
    NJ
    that is one of the split-channel JCM800's as opposed to the single channel 2203. So there will be a difference, but for $850, that's a good price and you should buy it.
    Crikey and Mitchell Pearrow like this.
  3. Mitchell Pearrow
    4,622
    5,204
    Jump Crikey that would be a fine stable mate, and 850$ is a damm good price! Cheers Mitch
    Crikey likes this.
  4. Gutch220
    Feb 19, 2018
    359
    182
    NJ
    Well you're right to start with the tubes. I'd swap out the tubes anyway if I bought another person's amp.
    Mitchell Pearrow and Crikey like this.
  5. Crikey
    Crikey Member
    Feb 16, 2019
    58
    90
    I plan to pull out the chassis clean the pots and check for bad solder. Looking at an old thread for same amp some suggested it could be several things, bad pots, bad tubes, cracked solder on pc board. Will try those first
  6. Georgiatec
    Apr 23, 2010
    5,029
    3,653
    Macclesfield, UK.
    Another boost channel dual concentric pot bites the dust. :rolleyes:
    Crikey likes this.
  7. Crikey
    Crikey Member
    Feb 16, 2019
    58
    90
    Good news. I pulled the chassis out and saw where the footswitch input was loose and installed it correctly. Turned on power with chassis out and pulled guitar in and Lord Sweet Jesus she ROARs!! Put chassis back in and sounds good but think it needs to have tubes biased.
    Georgiatec and Mitchell Pearrow like this.
  8. Mitchell Pearrow
    4,622
    5,204
    Excellent brother, I am glad you got it and got it going :cheers:
    Crikey likes this.
  9. Georgiatec
    Apr 23, 2010
    5,029
    3,653
    Macclesfield, UK.
    An easy fix, happy days mate. :fingersx:
    Crikey likes this.
