Marshall EL34M tubes
Discussion in 'Marshall Amps' started by StingRay85, Nov 16, 2019.
  1. StingRay85
    StingRay85 Active Member
    Aug 18, 2019
    159
    78
    I have an early 70s Carlsbro PA100 amp with these tubes inside. Can't seem to find good info on them. Anyone has seen them before? Would they be any good for a Super Lead?
  2. Dogs of Doom
    19,816
    20,003
    are there any #'s on them?
    There's a sticky, in the tube section, giving the codes...
  3. StingRay85
    Aug 18, 2019
    159
    78
    No codes whatsoever
  4. Dogs of Doom
    19,816
    20,003
    I forget, who made the dual square getter tubes.
    If they are in good shape, they should be good in any amp that is set up for EL34. If you have a tester, that would be optimal. Do they seem to work properly, in the amp you pulled them from?
  5. EADGBE
    EADGBE Well-Known Member
    Dec 13, 2009
    450
    311
  6. pedecamp
    13,629
    9,928
    EL34M thats what I run in my 2204, mine are from Groove Tube, my favorite power tubes in that amp. :yesway:
  7. ampmadscientist
    14,863
    8,724
    Watch out.
    The keyway is broken off of one of the tubes.
    keywaybusted.png This will allow the tube to be inserted incorrectly into the socket.
    This could cause major problems...
  8. StingRay85
    Aug 18, 2019
    159
    78
    I know. I can still see how to plug it in correctly. Thanks for the heads up though
  9. RickyLee
    May 22, 2010
    9,631
    3,113
    Riverside CA U.S.A.
  10. Dogs of Doom
    19,816
    20,003
  11. Dogs of Doom
    19,816
    20,003
    these are Philips Holland: (DD getter)
  12. Dogs of Doom
    19,816
    20,003
    another RFT: (dual halo)
  13. Dogs of Doom
    19,816
    20,003
    Mullard: (single halo)
  14. Dogs of Doom
    19,816
    20,003
    You'll have to find images of those horizontal flat square getters
  15. RickyLee
    May 22, 2010
    9,631
    3,113
    Riverside CA U.S.A.
    Old China 12AX7 had square getters. Maybe they are Chinese built?
