Marshall cab 1935B
Discussion in 'Cabinets & Speakers' started by rafalynch, Oct 13, 2019.
  1. rafalynch
    rafalynch Active Member
    Sep 4, 2014
    224
    105
    Hello, I bought online this cabinet Marshall 1935B, I still have not received it and I was wondering what year it may be and what speakers should be inside. I would appreciate any help request. Thank you
    Dogs of Doom likes this.
  2. rafalynch
    Sep 4, 2014
    224
    105
  3. rafalynch
    Sep 4, 2014
    224
    105
  4. rafalynch
    Sep 4, 2014
    224
    105
  5. rafalynch
    Sep 4, 2014
    224
    105
  6. rafalynch
    Sep 4, 2014
    224
    105
    the screws on the back cover look good ... they are not manipulated and everything indicates that the original speakers will be there, another thing is the state in which they are. Thanks for your help.
  7. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    8,673
    4,376
    Lakeland, TN
    I would think some G12M25 T1511's would be original as it is a 100 watt cab for bass. Great looking cab and good job!
    rafalynch likes this.
  8. rafalynch
    Sep 4, 2014
    224
    105
    Thank you very much for your help. When I arrive I will put pictures of the speakers.
  9. rafalynch
    Sep 4, 2014
    224
    105
    Yesterday I got the cabinet. The first thing I tried with a JMP head and it sounds fantastic, but when you open the back cover there has been a very strong smell of moisture, the speakers below have a bit of rust and the black cardboard membranes had some white mold. I applied a little WD-40 with a brush and with another dry brush I removed the white mold from the membranes. Nor was it too exaggerated but I don't think it's good for the speakers. I will leave it open a few days because where I live the environment is dry and I think the moisture inside will go away. I think the altavices are from 1975/76. Thank you
  10. rafalynch
    Sep 4, 2014
    224
    105
  11. rafalynch
    Sep 4, 2014
    224
    105
  12. rafalynch
    Sep 4, 2014
    224
    105
    [​IMG] [​IMG]
    Geeze likes this.
  13. BygoneTones
    BygoneTones Well-Known Member
    Aug 27, 2013
    1,100
    633
    the photos aren't showing, unless you right click and open in new window.
  14. BygoneTones
    Aug 27, 2013
    1,100
    633
    Looks like a nice cab from late 73. HF = Aug 73, JF = Sep 73. Those speakers are right on the transition from pulsonic cones to RIC cones, and from green backs to grey backs. The top left speaker is a pulsonic, you can see the '4' stamp, but you will need to check the others. Any RIC cones might be blank or have a yellow chalk marking on them.
    Damp marks on the cones is not a good sign, always get the speakers out and check them over. This should help:
    https://www.bygonetones.com/how-to-test-a-celestion-greenback-speaker.html
    Mainly you will want to check the spider supports. Very common problem, especially if the speakers have been damp. They will need repairing if they are lifting off.
    Be careful getting the speakers out if they are stuck to the baffle. Don't try to yank them out with brute force it will rip the cones. Use something thin and metal, like a feeler gauge, underneath until they are completely loose.
    Also try to preserve that wiring harness. Unsolder the wiring, rather than cutting through it.
    GIBSON67, rafalynch and soundboy57 like this.
  15. rafalynch
    Sep 4, 2014
    224
    105
    Bygone Tones, Thank you very much for your comments and advice, the speakers are several different codes. I thought it was 75 ... but if you say it is 73 much better, I will leave a few days more open the back cover to vent and moisture out.
  16. rafalynch
    Sep 4, 2014
    224
    105
  17. rafalynch
    Sep 4, 2014
    224
    105
  18. soundboy57
    soundboy57 Well-Known Member
    Dec 27, 2009
    2,684
    2,232
    Oregon
    I would love to see some photos. Can't open them, or see them.
    I have a 1973 1935A cab. One of the best cabs I have ever had for tone.
  19. rafalynch
    Sep 4, 2014
    224
    105
    Sorry, have now
  20. rafalynch
    Sep 4, 2014
    224
    105
    Speakers
