Marshall 6100LM Channel Switching w/ Midi Mouse Tech 21
Discussion in 'The Workbench' started by HOT TUBES 70, Jan 2, 2020.
  1. HOT TUBES 70
    Oct 13, 2008
    11,185
    5,656
    Does anyone know if this simple little midi controller does indeed change all the channels on the 6100 heads ?
    These are relatively cheap , but i need to know if they will work ?
  2. Jon C
    Jon C Well-Known Member
    May 29, 2017
    1,372
    2,373
    Wa State
    As long as the Midi Board is alive in the Amp …
    The UVEEPROMS Chip is subject to brown out …
    If it’s good , No Problem ……
    Midi Mouse will do the Deed
    HOT TUBES 70 and anitoli like this.
  3. HOT TUBES 70
    Oct 13, 2008
    11,185
    5,656
    Thank you Jon C !!!!
    Yes my 6100 is still fully functioning ...
    Jon C likes this.
