Marshall 30th Anniversary Series thread (6100 / 6101)
Discussion in 'Marshall Amps' started by Tonton, Dec 5, 2014.
  1. Jethro Rocker
    5,456
    3,802
    Unless I'm remembering wrong, when the loop is set to Series, which I do, I think the overall volume is then also adjusted by the Mix knob. If you want to also attenuate the volume some more, leave it lower but full up simply gives you full signal. If I remember...
  2. anitoli
    anitoli Well-Known Member
    3,863
    3,377
    Yup when set to series if you turn the effects knob counterclockwise the signal diminishes.
    Jethro Rocker likes this.
  3. Hexenhammer
    Hexenhammer New Member
    Tuesday
    Hello dudes...
    i just created my account to get some answers about my 6101 Combo. btw...sorry for some grammar mistakes...i´m german.
    I would like to run a Starfield VPA 1 Tube Pre- Amp via the Power Amp of the 6101. I tried it already and it worked out for about 6 minutes. then Volume turned down. I know there is a way to connect this two beasts, but im not sure, if something could get damaged etc. Have somebody ever tried something like this...? looking forward for some ideas.cheers
  4. Fender
    Fender Member
    Nov 14, 2017
    30
    7
    what do you mean by "the volume turned down" ?
  5. anitoli
    3,863
    3,377
    Use the line input to run external units. It disconnects the preamp and the power amp is used as a slave.
  6. Fender
    Fender Member
    Nov 14, 2017
    30
    7
    yup but i hope you didn't fry anything down the loop.
    This line input is a blessing too as you can use your amp to amplify boutique preamps as well... most versatile amp ever, maybe...
  7. anitoli
    3,863
    3,377
    An easy way to check the loop is to insert a jumper cable and try the amp. It will pass signal even with the poweramp mute button pushed in.
