Maintenance Job - 1970 Super Bass
Discussion in 'Let's Talk Vintage' started by Marshallhead, Dec 5, 2016.
  1. Marshallhead
    Marshallhead Well-Known Member
    Jun 3, 2009
    1,344
    521
    Job for tonight - new electrolytics for this old warhorse. Still has its original Eries at the moment.
    Kris Ford likes this.
  2. Kris Ford
    Kris Ford Well-Known Member
    Jan 3, 2015
    1,050
    737
    Detroit FTW
    My '74 is going in too, still has it's originals too, which I'm getting a crackling and staticy noise.
  3. neikeel
    2,070
    872
    Preventative maintenance or are they dying?
    Are those F&Ts or the MA ones?
    Interestingly I had a new ARS dual 16uF die on me in my offset clone after a few hours. Started smoking first (yes, you now the smell!) hot to the touch so that is how `i could tell it was that component smoking. Dropped in a new F&T 32/16 and all well at the moment.
    Good luck.
  4. Marshallhead
    Jun 3, 2009
    1,344
    521
    The amp has not been used for a few years aside from an occasional soft power up on a variac, so some preventative work before something goes wrong. I used MA caps.
    Job complete - pic below.
  5. Marshallhead
    Jun 3, 2009
    1,344
    521
    And the ones I took out. 5 Eries and a later Daly (I recall it had a bodge up in place of one can when I acquired it about 15 years ago and I put the Daly in there!)
  6. Marshallhead
    Jun 3, 2009
    1,344
    521
    Only problem I encountered is - I think the thermostat in my solder station must have gone bad - I suddenly noticed the tip and shank glowing red hot, even when I set the temp very low!
    I had to keep switch it off between shots and working very quickly when I did switch it on to use it.
  7. neikeel
    2,070
    872
    I have a Weller WTCP51 and I have been warned that this can happen to these if the magnet does not separate cleanly in the tube (alternatively can cut out if the contacts get oxidised otherwise they are pretty reliable) is yours one of these?
  8. Marshallhead
    Jun 3, 2009
    1,344
    521
    It's Maplin's own brand - but I think it's made by Weller. It has model no ZD-916 on it.
    When you say the magnet in the tube - what am I looking for?
  9. stickyfinger
    stickyfinger Active Member
    Nov 11, 2010
    305
    95
    Do you have a capacitance meter?
    It would be interesting to see what they measure to be able to compare how much of the "softness" or "mellowness" of old amps are contributed to the worn, presumably low filtering of the 40+ year caps.
    How the tone of the amp now?
  10. boola1
    boola1 Active Member
    May 17, 2016
    108
    53
    I've done the filter caps on all my old amps (40+ years) and it definitely makes a difference. It tightens things up and increases the clarity of the amp. The change isn't huge unless the caps were really knackered and I've never regretted changing them, the amp always sounds better.
    PS, I use Mundorf caps which some people might question but my ears approve!
  11. Kris Ford
    Jan 3, 2015
    1,050
    737
    Detroit FTW
    So if you want to go for a "tight, metal spec" tone, which is the recommended cap for the job?
    Soft and mellow I DON'T want..total aggressive metal panel tone is what I crave.:hbang:
  12. boola1
    May 17, 2016
    108
    53
    I have tried F&T, ARS and Mundorf. Of those 3 I would go for F&T.
  13. neikeel
    2,070
    872
    On my weller it is the tip and the part just behind the tip which determines the temperature at which it cuts out. The part behind the tip is spring loaded and makes electromagnetic contact with the tip (inside the hollow barrel) when it hits the correct temperature the tip loses its magnetic effect and the contact is broken. Simple but effective as long as the plunger can slide inside the barrel. Yours may just be a theremostat that has gone south looking at the pictures. I guess the question is whether it is the station or the pencil part that has stopped working. I have a cheap nad cheerful Weller 25w with fine chisel tip that I use for desoldering jobs, that always works (well until I jinxed it).
  14. Kris Ford
    Jan 3, 2015
    1,050
    737
    Detroit FTW
    Cool, thanks!
    What's the opinion on JJs?
  15. neikeel
    2,070
    872
    I prefer LCRs when I can get them, F&Ts are fine as are ARS, I also like RIFAs, only had a couple of JJs and one blew up on me (ok so an ARS has too now) each time the cap - not my wiring as the replacements have been fine. Just my :2c:
  16. Marshallhead
    Jun 3, 2009
    1,344
    521
    My meter does capacitance but you have to dunk the legs or tags into little slots on the body of the meter and the cans don't allow that!
    The amp sounds tighter now, the chronic ghosting that afflicted it before has gone, although it still has a 100Hz hum behind the note on single high notes when cranked right up. It doesn't interact with the note and give the ring modulator effect you often get with ghosting however.
  17. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,232
    1,117
    F&Ts are good as Rifa for new ones but the best ones I have tested are Frag Jan Zuerst (Specially mad for him by F&T) great for odd values as well.
    plexi
  18. matttornado
    matttornado Active Member
    Mar 14, 2012
    603
    174
    Just re-capped my 74 Superlead w/ F&T 50/50s & the amp sounds great! Doing maintenance as well. That along with a fresh quad of Ruby EL34 BSTRs. Sounds killa!
  19. Kris Ford
    Jan 3, 2015
    1,050
    737
    Detroit FTW
    My '74 is going in soon!
    I don't do my amps, best to leave with the pros. I can build a LP wiring harness from scratch, wire a cab, etc, but won't go inside my amp..I simply don't trust myself.
    matttornado likes this.
  20. boola1
    May 17, 2016
    108
    53
    A cap job is pretty easy if you're OK with a soldering iron. The only tricky bit is the cap which is mounted under the board, that always gives me grief!
