Looking for Speakers That Aren't Flabbly on The Bottom End
Discussion in 'Cabinets & Speakers' started by Ron Anchak, Aug 20, 2019.
  1. Ron Anchak
    Ron Anchak Member
    Jul 13, 2018
    33
    5
    I'm currently trying to downsize my rig. At the moment I'm going between a 2525H and a SC20H. I'm leaning towards the SH20H, it has a cleaner break up and a bit more defined tone. I play mostly classic rock and rocking country (if that's an actually description).
    I play Flying Vs with BB2 in the bridge and BB1 in the neck. I'm currently using a 1936 cab with two V30s. I'm using an OCD on the front end of the amp to help get the SC20H to get into the distortion area. What I don't like is my Low E string is not defined, it's sort of flabby. I have my pickups lowered which has helped. I'm not sure if some of this is the tonal quality of the cab, my cab is MDF not BB. I want that mid range bump and I don't know if the BBs are some of the problem or maybe I should try a different speaker.
    I know this is a long rambling thread.
    Here's what's important:
    Tone at a low volume - below 100dB
    Sustain, crunch, clarity
    I'm pretty set on a 212 cab, not set on the amp yet
    Any help would be greatly appreciated
  2. mtm105
    mtm105 Well-Known Member
    Feb 11, 2014
    3,884
    3,552
    NW NJ Exit 25
    steveb63 likes this.
  3. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,006
    946
    Could try to brace and seal the cab
  4. Ron Anchak
    Ron Anchak Member
    Jul 13, 2018
    33
    5
    I'll look for a 1966 cab or another 1936 JCM800 cab first. I'm not to excited about the MDF cab I have
  5. Ron Anchak
    Ron Anchak Member
    Jul 13, 2018
    33
    5
    I've never seen these before. I'll have to check them out
  6. Kinkless Tetrode
    Aug 17, 2017
    798
    895
    Just telling you straight up, V30s are already about the least flabby bottom speakers out there.
  7. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    1,108
    2,485
    Springfield, Ohio
    Maybe try a different OD pedal? I don't have an SC20 but I did have an OCD and used it with a DSL 20 and a SV20. It sounded ok but a little too beefy on the bottom. Then I got a Wampler Tumnus Deluxe...….It kicks the amp but doesn't change the tone.
  8. ampmadscientist
    13,031
    6,902
    Start the reactor. free Mars!
    A lot of this is the amp itself, not just a speaker.
    Although obviously a good speaker is worth what you are paying for it. It helps a lot to use a good professional speaker, there's no question of that fact.
  9. Emtbreid
    Emtbreid Well-Known Member
    Oct 22, 2018
    363
    474
    East Coast, USA
    Is that supposed to be like a vintage G12-65?
  10. Ron Anchak
    Ron Anchak Member
    Jul 13, 2018
    33
    5
    Well tonight the SC20H doesn’t sound that great. Last night it was my pick over the 2525H. One thing I did on the 2525H was pull out the clipping switch, this helped to eliminate a small amount of the flubbyness. Still not 100% happy, but an improvement.
    I tried a TS9DX, I don’t care for it in the TS9 mode, in the plus mode it’s not bad for a slightly over driven sound. I really don’t like my J Rocket Archer pedal, it just doesn’t work with this amp.
    Anyone got a 1966 or older 1936 cab for sale? I wonder if the MDF is causing some of the tone that I don’t care for.
  11. Emtbreid
    Oct 22, 2018
    363
    474
    East Coast, USA
    just out of curiosity, how are you using the TS? To push the front of the amp?
    Edit: what settings are you using on the TS? It’s been my experience that a gain below 9 o’clock on the pedal, level max makes the TS shine. Apologies if this is indeed the way you are already using it, just trying to help.
  12. mickeydg5
    21,751
    9,311
    People are quick to blame the speaker but it it always the amplifier(s) or signal with too much emphasized bass frequency.
    What are all the controls settings on each amplifier?
  13. Trumpet Rider
    Trumpet Rider Well-Known Member
    Nov 8, 2016
    1,546
    2,370
    The V30 is not a flabby speaker. Rock electric guitar is a mid-range instrument, not a full-frequency range instrument. It should be EQ'd to emphasize what it does well. In a band situation the guitar should sit in its tonal area and let the bass guitar and drums take care of the bottom. A deep bass-y guitar will get lost in the mix.
    Playing alone, we want to hear that full-range sound. I do. We all do. And it can be done to a point. It is easier to achieve a deep bass with a clean tone. The more gain/distortion, the harder it is to maintain a deep, tight bass tone.
    Kinkless Tetrode likes this.
  14. mickeydg5
    21,751
    9,311
    I like enough bass to give it body. Too much of anything is never a good alternative.
    I want my signal clean (although dirty you know) and mean.
  15. johnfv
    johnfv Well-Known Member
    Sep 29, 2010
    5,590
    4,118
    Austin TX
    Agreed. I suspect something else is causing the "flabby-ness"...
  16. mickeydg5
    21,751
    9,311
    Too much Chick-fill-A, perhaps.
  17. Emtbreid
    Oct 22, 2018
    363
    474
    East Coast, USA
    Is there such a thing?
  18. mickeydg5
    21,751
    9,311
    Chick-fill-A is like the Burger King of chicken. I stay away.
    If I want a burger I go to a real burger joint.
    The same goes for chicken, and steak, and crabs and lobster.
  19. Emtbreid
    Oct 22, 2018
    363
    474
    East Coast, USA
    Man, they must be bad near you. Here in central MD they are fantastic ! As far as fast food goes.
  20. Ron Anchak
    Ron Anchak Member
    Jul 13, 2018
    33
    5
    Presence 5.25
    Bass 5.5
    Middle 4.75
    Treble 5.5
    Master 10
    Volume 2
    Gain 8
    Tube Screamer
    Drive 5
    Level 2
    Tone 8
    If I lower the bass on the amp everything gets thin sounding.
    Chords sound great. Single notes on the low E aren’t exactly great.
