Longest Metro Plexi 50 Build
Discussion in 'Building the Classics' started by Exojam, Aug 4, 2018.
  1. neikeel
    3,641
    2,058
    Nearly there!!
  2. Exojam
    Exojam Well-Known Member
    May 31, 2017
    614
    391
    If can get to the point where I do not need more surgeries and get off the antibiotics I may make some real progress.
    How does she look so far?
  3. Exojam
    May 31, 2017
    614
    391
    Well it is all put together. In some ways I am happy with how it came out but the MAJOR OCM in me will see a wire that is not perfect and it will bother me.
    In the next few days it will go through it voltage checks without and than with the tubes. I will start it with JJ’s even though I just do not like them. Once I am satisfied with how that goes I will put my NOS tubes in. Not sure what will go in the preamp section but I have some (supposed to be) very nice Mullard matching power tubes.
    stryker59 likes this.
  4. Exojam
    May 31, 2017
    614
    391
  5. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    699
    383
    The black wire that you used on top of the board, is that shielded?
  6. Exojam
    May 31, 2017
    614
    391
    Yes it is.
  7. neikeel
    3,641
    2,058
    I think he is confused. It is insulated bus wire. It does not need (or appear to be shielded). The Metro/Valvestorm kit comes with correct bus wire and insulation. I would always encourage builders new to this type of build to do that and ideally use perf'd board to loop the correctly coloured wires through the holes to the turrets to help with trouble shooting if there are problems later.
  8. Exojam
    May 31, 2017
    614
    391
    Sorry for the wrong information.
    I definitely wish I would have ran the wires all the way through the turrets when I wired it up.
  9. Chris-in-LA
    Jul 19, 2018
    699
    383
    Run them from the bottom to the top of the turret? On my last build I just wrapped them around the base of the turret. I see that Metro has you fold the end of the wire and insert it into the bottom, is that what you did?
  10. Exojam
    May 31, 2017
    614
    391
    For those black wires and two others I wrapped them around the turrets.
    All other wires I installed as directed in the manual.
  11. Chris-in-LA
    Jul 19, 2018
    699
    383
    That build is very clean with the wires run from the bottom. I’m going to try that on my Metro 50 Plexi/2204 conversion project.
  12. Exojam
    May 31, 2017
    614
    391
    Thank you.
    I have to give Neikeel a ton of credit for always being there to offer his help and constructive advice. He is one very intelligent person when it comes to amps.
  13. Exojam
    May 31, 2017
    614
    391
    Well I ran into a problem when I started on the voltage checks, the 3 amp fuse was blowing.
    With the help of a few folks they noticed I wired the voltage regulator incorrectly. What a dumb as move on my part and as slow as go I am not sure how in the heck I pulled that one off but I did.
    Anyway, just waiting for some more fuses and I will rewire the voltage regulator and see what I get.
  14. Chris-in-LA
    Jul 19, 2018
    699
    383
    Voltage regulator? Is that the bridge rectifier?
  15. Chris-in-LA
    Jul 19, 2018
    699
    383
    Oh yeah, I see the problem but I wouldn’t have noticed it without you saying it, the wiring to the rectifier was wrong.
  16. Exojam
    May 31, 2017
    614
    391
    Yeah I meant to say rectifier and not regulator.
  17. Chris-in-LA
    Jul 19, 2018
    699
    383
    I’m getting ready to do a Metro kit with that same rectifier, did you get yours all sorted out yet?
  18. neikeel
    3,641
    2,058
    The rectifier is marked with ~ on two pins, +ve on another and -be on the fourth.
    The kit uses single pole switches so the PT is hooked directly to the ~ terminals and the + to the standby switch which then goes to the mains cans and choke etc. The -ve has no connection on a 50w. I personally prefer to use two double pole switches for mains (to switch live and neutral synchronously) and to switch the ac from the PT to the diode block But the kit arrangement is ok.
  19. Exojam
    May 31, 2017
    614
    391
    I just got my fuses in yesterday so after a bit of cleaning of my van that was totaled (getting all the stereo stuff out) I will be able to rewire and test a bit today (hopefully).
    And if you can do your kit like Neikeel mentions, I would. Unfortunately I reached out to him for help after I already purchased my parts.
    Chris-in-LA likes this.
  20. Exojam
    May 31, 2017
    614
    391
