Longest Metro Plexi 50 Build
Discussion in 'Building the Classics' started by Exojam, Aug 4, 2018.
  1. coolidge56
    coolidge56 Well-Known Member
    Jan 30, 2019
    387
    856
    8 is the sweet spot, 9-10 the quality of the tone begins to fall off imo.
    neikeel likes this.
  2. Exojam
    Exojam Well-Known Member
    May 31, 2017
    657
    412
    So yesterday I decided to make some measurements of the the system I was using looking at harmonics and a waterfall to see how bad my "guitar" room is.
    So the equipment being used is as follows:
    SG Gothic with David Allen Powerage pickups.
    The amp I just built in this thread with matching Mullard XF2 Single Halos for power tubes,
    V1 - Baldwin/Sylvania 12AX7
    V2 - GE JAN 12AX7A
    V3 - Raytheon JAN 12AX7
    Mesa Recto Rectifier 2x12 Cab Cabinet Celestion V30s England
    Setting of the amp are in a screenshot and guitar volume and tone were around 6
    Show with the screenshots, I split them up in a few ways. One has the fundamental and all harmonics, one has the fundamental and even harms, one has the fundamental and odd harms and maybe one more, there is a screenshots of the amp settings and one waterfall.
    wondering what some of you guys think of the harms, as for the waterfall (which I knew before even taking this one) is that the room I play in ABSOLUTELY SUCKS for acoustics.
    All harms in %
    even harms
    fund and all harms
    fundamental
    odd harms
    waterfall
  3. Exojam
    May 31, 2017
    657
    412
    I added another one real quick that changes the scale to db relative and i hovered over the fundamental so it is in yellow and easy to pick up which may make it easier to compare the harms to it.
  4. ampmadscientist
    16,528
    10,446
    "...the room I play in ABSOLUTELY SUCKS for acoustics."
    Install some bass traps in the corners of the room, and it can be a whole new amazing world.
  5. Exojam
    May 31, 2017
    657
    412
    Amp,
    That is the plan. I have corner traps and other panels in my family and man do they make a world of difference.
    I still (I believe) a whole box of 2”*2’*4’, 12 sheets of 203 in the basement I can use. I just need to pick out some fabric and build some frames.
    Not sure why more home players like myself do not do this in the guitar world. When I was big into speakers and subs it seemed more people would do this.
