Longest Metro Plexi 50 Build
Discussion in 'Building the Classics' started by Exojam, Aug 4, 2018.
  1. Exojam
    Exojam Well-Known Member
    May 31, 2017
    627
    397
    Well I have decided to start getting this build on the way. Have not made to much progress but I am in no rush at all.
    I am using Marstan PT, OT and choke.
    Picked up all the parts from Valvestrom.
    More pics when I make more progress.
  2. ampmadscientist
    14,985
    8,812
  3. Exojam
    May 31, 2017
    627
    397
    Well with being in the process of a 19 month period to stay alive and now recover, trying to fix this Blackstar HT100 Head, practice my guitar and have a family.
    It will be a long build time :eddie::eddie:
  4. Exojam
    May 31, 2017
    627
    397
    Plus a good 9”’s!
  5. Exojam
    May 31, 2017
    627
    397
  6. Big Mike
    Big Mike Member
    Nov 15, 2007
    58
    21
    Raider Nation - SFO Bay Area
    Heaters look pretty good, those are annoying.
  7. Exojam
    May 31, 2017
    627
    397
    Thank you. Yeah, getting my chubby fingers in there to twist them was not the most fun thing.
  8. Gunner64
    Nov 16, 2013
    5,248
    6,230
    Midwest, USA
    Try tying one end of the pair to something stationary and put the other end in a cordless drill and twist away..dont go too far though..no need to twist in the amp..I pre-twist.
    MarshallDog and Exojam like this.
  9. Exojam
    May 31, 2017
    627
    397
    Gunner,
    I had seen that done before but I was not sure if I could use that method due to one end of the wires being of different length. Plus, I was not sure how much extra I would have but I will pre twist going forward.
    Thanks for the input.
  10. neikeel
    3,687
    2,100
    The drill method works well but you do lose a bit of wire when you untwist enough to solder the ends in.
    Personally I don’t leave those long black loops in the preamp pin 9 wires.
  11. ampmadscientist
    14,985
    8,812
    That is long.
    Perhaps the longest.
  12. Exojam
    May 31, 2017
    627
    397
    What is the purpose of those loops if any (as I cannot see any benefit)? I just tried to make it like the instructions showed.
  13. Exojam
    May 31, 2017
    627
    397
    The 19 months was hardest shit I have ever been through, and being a para for going on 20 years, I have been through some tough goes of it.
  14. neikeel
    3,687
    2,100
    Don’t know really I think idea was to approach the sockets at 90 degrees and ensure the other wires crossed these at 90degrees to.
  15. ampmadscientist
    14,985
    8,812
    If the signal wires are parallel to heater wires, you get a lot of hum.
    If the signal wires are 90 degrees, you will pick up a lot less hum.
    But it actually helps to get the heater wires vertical straight up from the socket too. That's how Fender does the filaments.
    In this case heaters vertical and signal down near the chassis, the noise is reduced more.
  16. neikeel
    3,687
    2,100
    Yes that is what I said. :)
    What I am not sure is why such big loops as I think that they are more likely to encroach on grid wires and cause noise.
  17. Exojam
    May 31, 2017
    627
    397
    I told you guys it would be a long build.
    I had to put it down for awhile while I try and finish fixing (I hope) this Blackstar HT100 I had purchased that I purchased knowing it did not work. Getting close to wrapping it up and will see if I got it or not. Than back to the Plexi.
    I received the below wiring change (from the book) from the gentleman from Valvestrom.
    Notes:
    AC Line in -
    L (Hot) black wire to tip of mains fuse holder, sleeve of fuseholder to one side of power switch, other side of switch to brown (120) PT wire AND to one side of 120vac lamp
    N (Neutral) white wire to H on PT, H also goes to other side of lamp via a white wire.
    G to new, dedicated ground lug on end of chassis
    The other PT AC wires (1,3,4,5) should have individually heatshrinked tip then be bundled out of the way.
    PT Secondaries – To rectifier as indicated above.
    I use D & F initially, these will yield voltages that are more friendly to modern power tubes, C & G are higher voltage, can easily more the wires if desired.
    Heaters – to v5 as indicated above. J to ground lug
  18. Exojam
    May 31, 2017
    627
    397
    Well I had to jump ahead of the instruction manual and hooked up the below wiring, baby steps.
    Next is is to drill a hole in the chassis for a ground lug for “G” of the input power.
    AC Line in -
    FC37A022-6142-418D-9399-233FAD6D7109.jpeg 483EE839-2AC4-43B0-9E3B-F275FE154FFB.jpeg
  19. neikeel
    3,687
    2,100
    Normally you bring the ac wires in the corner of the chassis and then up from the front to the PT (ie dont have that white neutral wire there, run it under the rectifier in that loom bundle then up to the lug. You will shrtly take another white wire from the HT lug to the bias feed on the board;)
  20. Exojam
    May 31, 2017
    627
    397
    No problem, that will just take a few minutes to unsolder the connections and run another piece of wire. Thanks.
