Leslie / Overdrive Pedals?
Discussion in 'The Tone Zone' started by jmp45, Aug 20, 2018.
  1. jmp45
    jmp45 Well-Known Member
    May 5, 2016
    1,377
    1,439
    Is there a pedal or combinations of a rotary and drive that can get into the ballpark of Joe's Barnstorm era? Not interested in springing for a leslie. I haven't heard any pedal demos yet that can get to this. Several examples from Joe's early work, this is one.
    tomsvintage likes this.
  2. mtm105
    mtm105 Well-Known Member
    Feb 11, 2014
    3,737
    3,113
    NW NJ Exit 25
  3. jmp45
    May 5, 2016
    1,377
    1,439
    Not quite what I'm looking after, but thanks!
  4. El Gringo
    El Gringo Well-Known Member
    Jul 24, 2015
    982
    676
    Shakedown Street
    What about a Dunlop Univibe
    jmp45 likes this.
  5. jmp45
    May 5, 2016
    1,377
    1,439
    Thanks, I have a Fulltone MDV-2 and a couple fuzzy pedals. I'll gang them together and see what I can come up with. The MDV-2 is in front of the chain, not sure if that is a plus or not for this.
  6. El Gringo
    Jul 24, 2015
    982
    676
    Shakedown Street
    I just looked up the Fulltone MDV-2 and you should be good to go with that pedal . I would probably not have that in the front of the chain .I would have my wah, then fuzz ,then overdrive then your modulation type pedals (Flanger , chorus, Phase and so on then lastly your delay type pedals ) The vibe type rotating chorus type sounds fall into the modulation pedals . Fulltone makes good products that is for sure !
  7. jmp45
    May 5, 2016
    1,377
    1,439
    It would take some changing around to accommodate that on my board. Thomas wah -> MDV-2 -> Dirt -> Mod -> Delay. I do like how it behaves in the front of the chain though. Sounds amazing with v-twin or be-od behind it.
  8. axe4me
    axe4me Well-Known Member
    Feb 28, 2013
    3,438
    2,890
    jmp45 likes this.
  9. mirrorman
    mirrorman Well-Known Member
    Mar 30, 2014
    631
    627
    Canada
    You might want to try an Electro-Harmonix Lester G.
    IMO, it does a real nice Leslie impersonation.
    jmp45 likes this.
  10. jmp45
    May 5, 2016
    1,377
    1,439
    Thanks Mirrorman, that may be what I'm looking for.. There are a couple settings in this demo that gets close to that neighborhood.
    El Gringo and mirrorman like this.
  11. purpleplexi
    purpleplexi Active Member
    Feb 14, 2011
    162
    132
    Ventilator is the best I've heard but IIRC it doesn't have any gain.
    jmp45 likes this.
  12. jmp45
    May 5, 2016
    1,377
    1,439
    Thanks, I liked the drive of the lester g, that's what sold me on that. It's on my list.
  13. jmp45
    May 5, 2016
    1,377
    1,439
    I picked up a used Lester G. It sounds great but it most definitely needs to be in am isolated loop. I noticed a little loss coming out of the boards at the end where I was testing it. I'm going to put it in front of the nebulus in the same loop. I have a ton of effects on those boards but they are isolated in loops. Never more than 3 running behind the wah and mdv-2.
    The pedal shines best with it's onboard drive. I tested with others in front with not very good results. Onboard drive and comp are very interactive, a good thing. Not using it in a stereo setup, that might make it a little more interesting. It's not going to be setup that way on the board.
    mirrorman likes this.
  14. tomsvintage
    tomsvintage Well-Known Member
    Jun 11, 2012
    674
    426
    JTM45 Headquarters
    How about the Hughes and Kettner Rotosphere ? It has a drive and output control as well as a cool Leslie sound that can ramp up and down ( version 1 ) with the momentary breaker footswitch.
    Sounds much better through some Marshall's like Joe was using during that era. :)
  15. jmp45
    May 5, 2016
    1,377
    1,439
    Not bad. For the $ the Lester G is good enough for my use. There is more settings to work with, acceleration, slow and fast speed, brake, balance from speaker and horn (a tone control...;), drive and compressor. On the board now. The synth9 might be going away and replaced with a muff I have laying around. Excessive I know, but they have their place.
    mirrorman and tomsvintage like this.
  16. mirrorman
    Mar 30, 2014
    631
    627
    Canada
    Have fun with your new toy!
    I've had mine for about a year, no issues.
    I've found that using the onboard drive and compressor gives very nice results...much better than using some other overdrive or distortion with the pedal.
    I use mine with clean or almost clean amp settings, front of amp with the "Squash" switch engaged.
    :h5:
    jmp45 likes this.
  17. jmp45
    May 5, 2016
    1,377
    1,439
    Thanks MM. I'm finding it useful about the same. Mostly clean, slight drive and squash. Slight over noon on slow, slight less on fast.
