Legit Or Snakeoil?
Discussion in 'The Workbench' started by anitoli, Aug 7, 2018.
  1. anitoli
    anitoli Well-Known Member
    5,741
    5,894
    What you boys think about these?
    https://www.thetubestore.com/parts-...il&utm_term=0_de9dfae6f1-50267c1e03-302144489
    MarshallDog likes this.
  2. Gunner64
    Gunner64 Well-Known Member
    Nov 16, 2013
    4,351
    4,566
    Midwest, USA
    Legit. I have seen simular rings used In tube stereo situations and they are supposed to cut the vibrations/microphonics. I have never needed them myself, as microphonic tubes get pulled in my world.
  3. Micky
    Apr 29, 2010
    19,857
    15,793
    Vermont
    The DSL40c comes with one, although it is just a cheap grommet that fits. That is all you need, an o-ring or such, don't spend a lot of money on this.
    KraftyBob, Dogs of Doom and Gunner64 like this.
  4. anitoli
    5,741
    5,894
    Yeah, at $23 a pop for an 12AX7 guess i'll be wondering for a long time.
  5. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    7,697
    4,568
    $24 each for 12AX7, $31 each for EL-34, $40 each for 6L6.
    A quad of those rings cost as much or more than the Tubes lol.
    Those rings prolly cost 5 cents each to manufacture.
    Sounds Swampy to me ...
    Nik Henville likes this.
  6. mickeydg5
    20,068
    7,946
    I believe Marty use to use some sort of red grommets to dampen tubes. They are cheaper, much cheaper.
  7. wakjob
    wakjob Well-Known Member
    Dec 29, 2011
    4,825
    3,005
    C-137
    yeah...um...
    I just bought the cheap brick red colored silicone ones,
    and they work just fine. Don't think I'll be getting these.
    neikeel and mickeydg5 like this.
  8. chee16
    chee16 Active Member
    Apr 12, 2013
    823
    199
    Chatham, Ontario, Canada
    I have the red high heat silicone ones too. No need for anything expensive based on their function. I think I got mine on eBay.
    wakjob likes this.
  9. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    10,232
    8,138
    Taintville
    I have these on my 12AX7s on combo amps. Not needed on heads obviously. These last and do reduce tube rattle. I have used the cheap red o-ring ones and they dry out and fall apart. These have lasted me over 5 years and counting. You get what you pay for!
  10. ampmadscientist
    11,624
    5,675
    Left Coast
    They actually do work.
    No it is not snake oil.
    The ring increases the mass of the envelope and lowers the resonant frequency. The idea is to make the resonant frequency so low that the ringing is stopped.
    Some principle used in hi fi phono tone arms.
    Fender HRD has one also:
  11. tschrama
    tschrama Well-Known Member
    May 15, 2010
    1,027
    351
    Netherlands
    snake oil!
    It adds mass but no damping. The added mass can cause microphonics just as likely as avoid it.
    The price is ridiculus.
    use tube retainers instead, or a alluminum bar as Mesa does in some combos
  12. GT08
    GT08 Active Member
    May 31, 2016
    267
    163
    Well in this case if it's anything it's daylight robbery that's for sure. You would be a real mug to buy these.
    Rock n' roll
  13. MarshallDog
    Nov 28, 2010
    10,232
    8,138
    Taintville
    Basically until you try them, do not knock them.
    And, how can anyone comment until they try them:scratch:
  14. ampmadscientist
    11,624
    5,675
    Left Coast
    Boogie does the same deal on preamp tubes also.
    They wrap the tube in foam to stop it from ringing.
  15. ampmadscientist
    11,624
    5,675
    Left Coast
    I know just from many trails and tests that
    it definitely works.
    There are many different methods, and designs...
    [​IMG] Herbies, about $27
    [​IMG] Eurotubes, about $5.00. The larger size adds more mass making the frequency lower, probably more effective.
    The silicon is heat resistant. Good design, good price.
    VTS- vintage tube services, hand made not mass produced.
    Probably one of the best designed dampers, about $120 a pair. High end performance because the frequency is lowered below the frequency response of the amplifier and speakers.
    Bermuda Audio tube dampers, 15-35 Euro.
    Cool Dampers, about $35.
    Brass Ring about $13.00
    Copper Stopper = about $25
    The Original Idea:
    comes from Hi Fi. Hi Fi has similar microphonic problems because of the resonance of phono turntables.
    You can learn a lot from those Hi Fi guys.
  16. ampmadscientist
    11,624
    5,675
    Left Coast
    Tube retainers don't stop the ringing, of this you can be certain.
    [​IMG] Practically useless...
  17. ampmadscientist
    11,624
    5,675
    Left Coast
    Most professional tube dampers are right in that price range. AND: PS these do work.
  18. RobS
    RobS Active Member
    Apr 19, 2009
    873
    130
    Melbourne - Australia
    the red Bermuda damper looks like the oil filter collar I use on my Harley for cooling!
  19. charveldan
    Jan 31, 2010
    7,697
    4,568
    And to think for 40 years ive been doing it wrong because i don't use $200 bucks worth of Silicone.
    Antmax and J5684 like this.
  20. LPMarshall hack
    Nov 18, 2009
    9,584
    7,397
    San Diego, CA
    $200??? You forgot a few zeroes.
