Kitchen Sink Mod , Burning Tubes
Discussion in 'The Workbench' started by Loud and proud, Jan 18, 2019.
Tags:
  1. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    8,248
    5,125
    https://www.ebay.com/itm/New-4x-Tun...WKSal:sc:USPSFirstClass!63139!US!-1:rk:1:pf:0
    Ive dealt with this guy for a while, good seller, closely matched.
  2. printer
    printer Member
    Sep 30, 2017
    91
    93
    So the power section is nothing out of the ordinary. I don't see the preamp as being anything that should effect the stability of the outputs, they don't care if the distortion is coming from the preamp section or a dirt pedal.
  3. NewReligion
    Nov 17, 2009
    11,074
    7,942
    Paradise
    Exactly. My 1976 Super Lead Friedman Kitchen Sink is stock Marshall Power Amp other than the PI cap and NFB which will not be the issue.
    I still have not heard if the owner looked to ensure the fuses are not over rated. That is the starting point.
    David
    charveldan likes this.
  4. 67Mopar
    67Mopar Well-Known Member
    Jun 14, 2011
    1,917
    2,404
    That Hopkins Marshall board is identical to the one I had built for me by Brian @ RTB.
    NewReligion likes this.
  5. NewReligion
    Nov 17, 2009
    11,074
    7,942
    Paradise
    If you are referring to the board on the cover of my signature, that is a Brian turret board. I populated it and installed it into a 1987 back in 2011. It was my first shot at learning on a larger scale. Figured I could play with it like the components were Lego’s. Worked out well for me. I found I preferred Mallory & Sprague caps over the Sozo’s immediately lol.
    Did you listen to the video?
    David
    67Mopar and charveldan like this.
  6. 67Mopar
    Jun 14, 2011
    1,917
    2,404
    Yeah... I wanted the board to be solid (no through-holes), so that I could wire it from under the board. I had to measure out the standoff mount placements, situated how I wanted the turrets positioned, and sent them to Brian for production. I still have the original template. He decided to post my 1987S rebuild on the front page of his website, which was cool! Don't know what I ever did with the original PCB? That was one of the best sounding Marshall's I've ever owned. Should never have sold it.
    Here's the board...
  7. NewReligion
    Nov 17, 2009
    11,074
    7,942
    Paradise
    I am not able to view the image.
  8. 67Mopar
    Jun 14, 2011
    1,917
    2,404
    ? I'll try again...
  9. NewReligion
    Nov 17, 2009
    11,074
    7,942
    Paradise
    Very nice and clean.
    67Mopar likes this.
  10. Loud and proud
    Loud and proud New Member
    Jan 18, 2019
    I am going to check the bias first thanks ampmadscientist
  11. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,414
    1,364
    Looked for a second like those resistors were laid out to spell Marshall.... lol
    67Mopar likes this.
  12. Loud and proud
    Jan 18, 2019
    Thanks I have read your post and am going through the process of eliminating any of these problems which my amp may have. Question what type of fuse should I run and where do I purchase online. I am in the sticks no stores for miles, thanks
  13. NewReligion
    Nov 17, 2009
    11,074
    7,942
    Paradise
    Your fuses and their proper rating should be listed on the back of the amp at the fuse holders. Get Slow Blow and check the length as they can come in 1 of 2 lengths. Either 5x20mm OR 1-1/4" x 1/4"
    Buy Here at Tube Depot. https://www.tubedepot.com/t/diy-central/fuses-and-fuse-holders
    100 Watt Super Lead etc..
    Mains 4 Amp
    HT 1 Amp
    50 Watt Wtt etc...
    Mains 3 Amp
    HT 500mA That means half of am amp.
    Keeps us in the loop.
    David...♫
