JTM45 Fit Into A 24" Wide Box?
Discussion in 'Building the Classics' started by bgreed2, Jan 9, 2020.
  1. bgreed2
    bgreed2 Member
    Sep 22, 2010
    49
    16
    Ventura, CA, USA
    I am looking to utilize a 2061cx cab (24" wide) due to it's portability over a 1960, so am wondering if a reissue JTM45/2245 (normally 26" wide) would fit into a smaller, 24" custom made (Mojo-tone, Sourmash, etc.) box. Thanks.
  2. South Park
    1,185
    892
    I don’t think the numbers work. You would be better off building a whole new box . I live in Oxnard if you need a table saw let me know
  3. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    1,252
    2,047
    How wide is the reissue JTM45/2245 chassis? If [what I call a] 50 watt chassis was used the answer is yes. The '50 watt' chassis used on JMP's is 18.5" [ish] wide. I've stuffed one into a 20" head cab.
    Russ
    bgreed2 likes this.
  4. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    699
    383
    The 50 watt Valvestorm chassis is about 18 1/2 inches long and so is their JTM45 chassis.
    bgreed2 likes this.
  5. Kinkless Tetrode
    Aug 17, 2017
    971
    1,153
    With a JTM45 the height is probably the more important dimension to be concerned about. Especially if one plans on using KT66s.
    Mojo makes a 24" wide head cab for the JTM45, but the height is about 10". The 45 short box cabs also usually have vents on top for the KT66s.
    bgreed2 likes this.
  6. bgreed2
    bgreed2 Member
    Sep 22, 2010
    49
    16
    Ventura, CA, USA
    The only dimensions I was able to dig up is from the JTM45 repro kit folks, at a 17-1/4" width. The original Marshall chassis was/is 18+" width. If I end up with a special order it looks like only the faceplate cutout with need to be altered or widened.
  7. Geeze
    Jul 25, 2015
    1,252
    2,047
    Amen to that! On my first KT66 headshell I had to drill a pair of 2.125" holes above the KT66's as I had a whopping .125" 'headroom' for them in a 9" tall cab.
    The second was 10" tall.
    Russ
  8. bgreed2
    bgreed2 Member
    Sep 22, 2010
    49
    16
    Ventura, CA, USA
    Thanks for bringing this to my attention.
  9. neikeel
    3,641
    2,058
    Yes the steel chassis is a smidge over 18" wide, if you include the mounting flanges, so realistically the narrowest you can go is 20" which is well within your 24" limit. You can use 7581A which are pretty close to KT66s but even stock head cabs are a bit tight for KT66s (always mount your tube sockets inside the chassis, not on top.
    Kinkless Tetrode likes this.
  10. neikeel
    3,641
    2,058
    Do the Mojo ones have vents?
    The original JTM45s would not have had vents in them.
  11. bgreed2
    bgreed2 Member
    Sep 22, 2010
    49
    16
    Ventura, CA, USA
    To be a little more clear, my intention is to buy a reissue JTM45 and have another smaller width box made to put it in.
    I currently own a 2061x but am just not getting enough headroom with it. It's only a 20w so perhaps the next amp up, power-wise, would be better. We'll see!
  12. Kinkless Tetrode
    Aug 17, 2017
    971
    1,153
    I just looked on their site and apparently they do not make a short box head box with vents anymore.
    To the OP they do make an extra tall 20" wide head box. I'm not really sure that 9.25" tall without vents is tall enough for KT66s , though.
    bgreed2 likes this.
