JTM Clubman New 18 Watt Amp With Vintage Parts
Discussion in 'Building the Classics' started by pleximaster, Nov 20, 2019.
  1. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,482
    1,526
    Made this 18 watter for Thomas Hinson (Tom vintage here on the forum)
    I made it out of old parts that Tom and I had. Wanted to make the JTM amplifier Marshall never made... :)
    plexi
  2. Guitar-Rocker
    Mar 5, 2012
    2,746
    2,335
    Indianapolis, Indiana
    Looks like the amp has a 1974 based theme that was started with, and the Normal side changed to JTM? Also looks like a EZ81 rectifier and maybe EL84 output tubes?
    Very nice job, by the way !
    ibmorjamn and pleximaster like this.
  3. neikeel
    3,654
    2,077
    Very nice
    Looks and sounds very similar to my 18watters, although I can't see what has been done off the board!
    tomsvintage and pleximaster like this.
  4. shakti
    shakti Member
    Jul 14, 2016
    93
    55
    Agree, very nice sound. But it appears to be stock 18w into a 4x12, unless there are mods outside the board that we can't see. The old components and transformers is the key here. A good 18w is so fun and effortless to play!
  5. pleximaster
    Feb 6, 2012
    1,482
    1,526
    Thanks
    Its mostly minor value changes here and there, more to get the sound and feeling towards JTM vs JMP
    Not so much schematic wise.
    Then Tom plays a lot of Stratocaster so I used my Strats a lot in the design and while tweaking it
    Originally the idea was to just make an 18 watt clone in head form so you could use different cabs more easily then a combo
    It sort of evolved a bit from that and then a lot of trial and testing of different components
    Neither of the transformers were the ones originally thought to be used. First MT was changed so it hand be wired for Toms 110 voltage in the US (haven’t tried that yet... ) and the first OT (older version of the RS transformer) was great sounding but had serious “vibrating/singing” issues (core acted like a speaker coil) and I replaced it with this one as singing transformers often turn bad as the coil wiring vibrates agains each other or the coil and insulation breaks
    Tremolos have always been an Achilles heal for me when repairing old Marshall’s and I made a few changes. It’s pretty massive perhaps a bit too much for purists...
    Plexi
    shakti likes this.
  6. Chris4189
    Chris4189 Well-Known Member
    Jul 10, 2018
    218
    279
    Schematic or it didn’t happen ;) I thinks it’s a great sounding amp! Well done sir!
  7. tomsvintage
    tomsvintage Well-Known Member
    Jun 11, 2012
    698
    492
    JTM45 Headquarters
    Excellent work pleximaster :) :) !! It sounds just as nice as it looks !! I am looking forward to using this great amp through my alnico loaded 4 x 12 !!
  8. shakti
    shakti Member
    Jul 14, 2016
    93
    55
    The tremolo on my 18w build (original chassis and OT, old stock parts) has the same hypnotic quality. Very cool tremolo on these even in stock form.
  9. neikeel
    3,654
    2,077
    Over the weekend I will post pics of my 18w Trem head built earlier this year with NOS parts. I am bad because I put a gold block logo on mine. Glad that OT sounds good shakti:)
    shakti and tomsvintage like this.
  10. ricksdisconnected
    Aug 11, 2019
    1,012
    1,560
    who is playing?
  11. neikeel
    3,654
    2,077
    It is Johan S isn't it?
  12. pleximaster
    Feb 6, 2012
    1,482
    1,526
    Yes of cause! :)
  13. ricksdisconnected
    Aug 11, 2019
    1,012
    1,560
    did not know he was a member here.
  14. pleximaster
    Feb 6, 2012
    1,482
    1,526
    At some points people have had him and me mixed up... :)
    plexi
    ibmorjamn and tomsvintage like this.
  15. danfrank
    danfrank Well-Known Member
    Mar 5, 2015
    972
    503
    Hi Pleximaster!
    I haven't been on here in a while but I just got through Johan's video on this amp... Great job! The amp sound terrific! I think a lot of people will be into this amp because it's a popular size for people to use.
    Great work!
    I hope you are doing well.
    pleximaster likes this.
  16. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    7,060
    4,662
    North
    He is a member here , I have not seen him here lately. Nice amp , I am not a Strat player and not in to the tremolo amp but that could be another gain stage instead I suppose right ?
  17. pleximaster
    Feb 6, 2012
    1,482
    1,526
    Hi Dan!
    How are you? We should ha a chat!
    About the Marshall Pigs I have another one in the loop of being restored, haven’t finished it (probably had it for the last too years, missing some parts and time, I am also instructed by my doctors not to lift heavy... ) must finish it someday
    How are your builds and restorations going?
    Plexi
  18. pleximaster
    Feb 6, 2012
    1,482
    1,526
    The Clubman doesn’t have an extra gainstage it actually pretty close to the original. It is more cherrypicked values and selection of parts that are changed.
    Plexi
  19. neikeel
    3,654
    2,077
    Not hijacking, just sharing the premise:
    Bare chassis and head cab from StevesUK (part in trade). Well made, although I might have had the cab made not quite as tall if I had drawn it up myself. As you see I used correct original RS transformers and NOS parts (apart from the electrolytics). I used the ceramic discs a little more than I would normally and they definitely add some grit and interest when you drive it.
    It is, as nearly everyone else claims about a new build, sounding fantastic, just like the clips made by Johan above, and my 2x12 combo. Sounds pretty huge through any of my 4x12s.
    Interestingly the little combo it sits on is based on a Ceriatone 18w in a Reason 1x12 cab. I built it with a Scumback G12H55 (Weber era) and it sounded pretty good but I dropped in a G12M modern 16ohm greenback and it has really come alive, maybe because you can drive the amp a little harder with the less efficient speaker. EF86 channel is noisy (despite various tweaks) and, when I get time I will sub a 12AX7 in the previous EF slot, cascade it for SLO type gain and be done.
    Pleximasters post and Johan's clips demonstrate how good that first design and build concept by Marshall (pinched from Watkin's??) was.
    This is the layout I used:
  20. Guitar-Rocker
    Mar 5, 2012
    2,746
    2,335
    Fantastic looking build, thank you for sharing the photos.
