JTM-30, Different Problem, PLEASE HELP!
Discussion in 'Marshall Amps' started by Gene Ballzz, Feb 19, 2013.
  1. slide222
    slide222 Well-Known Member
    Apr 5, 2013
    2,566
    1,642
    cambridgeshire uk
    and the great thing about marshall is they checked the mods out before they biased it - if you in the uk its just easy.
    mitch , you say was
  2. Mitchell Pearrow
    8,998
    13,807
    Yes we lost him on 12/15/07
    He stepped out onto a busy street and was hit by a truck.
  3. slide222
    Apr 5, 2013
    2,566
    1,642
    cambridgeshire uk
    so sorry to hear that bud,
    pete
  4. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    7,128
    4,768
    North
    I have one on the way , I read another post from back in May of 19 . One guy who had a JCM 900 liked it as well . Since I let my JCM 900 go I have not owned a Marshall I would keep. I hope this will change that.
    Mitchell Pearrow and slide222 like this.
  5. slide222
    Apr 5, 2013
    2,566
    1,642
    cambridgeshire uk
    if you like 900's you will love the red channel , I am certain of that , and these were only made for 3 years ,
    ibmorjamn and Mitchell Pearrow like this.
  6. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    1,876
    1,336
    Las Vegas, NV
    @slide222 is helping to confirm my allusion to the fact that whenever discussing a JTM30, folks who own a JTM60 tend to chime in with the assumption that they are similar amps. THEY ARE NOT, AT ALL! They ar not even close to the same! No offfense intended to slide222.
    @ibmorjamn
    I'm curious as to which of these amps you have found? JTM30 or JTM60?
    @Mitchell Pearrow
    So sorry to hear about your son. How old was he? My heart really goes out to you. Children are supposed to bury their parents, NOT the other way around!
    Just My Thoughts,
    Gene
  7. wmachine
    wmachine Well-Known Member
    Dec 18, 2015
    235
    332
    Ohio
    Please explain how they are not even close to the same.
    slide222 likes this.
  8. Mitchell Pearrow
    8,998
    13,807
    Jerry was 30 years old
    8/31/77 - 12/15/07
  9. ibmorjamn
    Nov 3, 2012
    7,128
    4,768
    North
    Mitch , I have no words.
  10. ibmorjamn
    Nov 3, 2012
    7,128
    4,768
    North
    @geneballzz JTM30 .
  11. Mitchell Pearrow
    8,998
    13,807
    None are necessary, my son Jarrod was killed in an automobile accident on 2/9/06 he was only 23 they were both very close, and left us very close.
    ibmorjamn likes this.
  12. Gene Ballzz
    Feb 19, 2013
    1,876
    1,336
    Las Vegas, NV
    @Mitchell Pearrow
    So sad to hear. Thank you for honoring us by sharing their names!
    While the cosmetics and "GUI" may seem similar, that's where the similarities end. The schematics tell the real story much better than I ever could. If not versed at deciphering schematics, you'd likely be confused even more by my gibberish.
    Just My $.02,
    Gene
  13. slide222
    Apr 5, 2013
    2,566
    1,642
    cambridgeshire uk
    I thought they were the same design ,60 watt just bigger , aren't the power tubes horizontal also , but I have only seen mine in real life , never seen a 30 watt
  14. slide222
    Apr 5, 2013
    2,566
    1,642
    cambridgeshire uk
    I haven't found my JTM60 to be a one sounding amp altho you say that the 30 you have is completely different to mine , but on mine , I can go from a mark knofler sound to an ultra gain sound very easy, infact I can get most marshall sounds from it
    it is very versatile- I don't understand what you mean by calling it a one sounding amp and then on your 2nd post you say its the most versatile amp you've had
    I too would like to know how the JTM30 varies ,just out of interest really
    we could do with ampmadscientist's thoughts here , he has lots of knowledge on these amps
  15. jtees4
    jtees4 Active Member
    Sep 21, 2010
    221
    193
    I had a JTM-60 1x12 for a couple of years, I bought it well used....I thought it was a great amp. I was concerned about it burning up, and it did have a hum....I decided to get rid of it before It started to have serious problems, as I no longer gig and have been using solid state/modelling amps for home use. It was the best Marshall I ever had since my (60's) Marshall Major which I got around 1976/77 when I was heavily gigging. You know, I really needed the Major for playing all the samll clubs around NYC and area :agreed: (hey....image matters!).
  16. wmachine
    Dec 18, 2015
    235
    332
    Ohio
    Common, Gene you (or someone) are going to have to do better than that. Sure they will have different schems. But if there is a "difference that makes a difference" then someone should be able to tell us what difference it makes! (Not just what the difference is)
  17. ibmorjamn
    Nov 3, 2012
    7,128
    4,768
    North
    From looking around the web Dr. Tube shows JTM 60 4 ecc83 and 2 el34's
    JTM600, 60W head
    JTMC410, 120W 4x10" cabinet
    This 60W head was introduced in 1996 and used four ECC83's and two EL34 tubes. It offered 2 independent footswitchable channels, each with their own EQ, a spring reverb with dual controls (one for each channel) and a series FX loop and a parallel FX loop.
    The JTM 30 has one less preamp tube and is set up for 5881 power tubes.
    As far as reading the schematic , I can sort of read it but the later models are much more complicated. I don't think I would do a lot of mods to the 30w just because if I want a modern 2204 I will get the studio classic.
  18. slide222
    Apr 5, 2013
    2,566
    1,642
    cambridgeshire uk
    did it say when the 60 was discontinued
  19. Gene Ballzz
    Feb 19, 2013
    1,876
    1,336
    Las Vegas, NV
    Ad to that the fact that the "diode clipping" was implemented i a very different manner and you have two very different amps. FWIW, I believe the JTM60 was released earlier in the '90s, along with the JTM30, but got it's nomenclature changed to JTM600 at the time the JTM30 was discontinued which corresponds with that 1996 date mentioned by @ibmorjamn .Funny thing is that from a useability standpoint the 60/600 seems like a better amp but both of those were plagued by many problems, but the 30, not so much!
    Just Sayin'
    Gene
  20. ibmorjamn
    Nov 3, 2012
    7,128
    4,768
    North
    @geneballzz , got the amp it has Issues . Thread :
    http://www.marshallforum.com/threads/new-amp-day.110892/#post-1906459
