JMP1 - Weak Sound
Discussion in 'The Workbench' started by JPRS, Aug 19, 2019.
  1. JPRS
    JPRS New Member
    Aug 19, 2019
    Hello all, greetings form Portugal.
    My preamp jmp1 when in OD 1 or 2 has sound, but its not the usual volume. I have to crank the volume all way up to get a room level volume.
    In clean mode, all cranked up. I only get a very very weak noise when strumming the guitar.
    Sometimes when in OD mode there are some slight volume variations.
    Tried 2 power amps. Same problem
    It is the second time it happens. The firs time after some minutes and rechecking cables it was ok again. But now again, it is definitely no cable.
    any thoughts?
    Cheers!!
  2. Dogs of Doom
    20,154
    20,558
    did you ever get this sorted out?
    There are "pad" buttons for each output. It could be anything though...
  3. ampmadscientist
    15,602
    9,521
    Welcome to the forum JP :cheers:.
    The symptoms you are describing could be a couple of things.
    A. First change the 2X 12AX7 preamp tubes inside the unit with new tubes, and then re-test.
    B. Plug a guitar cable between send and return, then re-test.
    C. If either of these doesn't solve the problem, it's likely there is a broken solder connection somewhere on the circuit board.
    The unit is static sensitive therefore special soldering equipment and static precautions are required to work on this unit. This is not a joke because 1 static discharge can destroy the unit circuitry.
    This unit should be worked on by a qualified technician recommend Marshall service center.
