JMP1 into GSP1101 loop
Discussion in 'Marshall Amps' started by Eddierocks, Jan 18, 2020.
  1. Eddierocks
    Eddierocks New Member
    Jun 25, 2014
    23
    Wolverhampton UK
    Hi.
    Just a quick question.
    My JMP1 is in the loop of a GSP1101.
    What should I set the output dials to on both units?
    If JMP1 is fully on, will it overload the GSP loop?
    Cheers
    tce63 likes this.
  2. Frodebro
    Frodebro Well-Known Member
    May 14, 2014
    4,136
    4,877
    Seattle
    IIRC, the loop in the Digitech is designed to accept a preamp, so a line level signal should be fine. I haven't fired mine up in quite a while (GSP1101), but I did used to run a tube preamp in it with no issues. I don't recall if I had to set up anything particular in the loop parameters, though. Either way, there's no need to crank up the master volume on the JMP-1, it's not going to sound any different than it will with the volume lower.
    tce63 likes this.
