JMP Lead 50 Watt 1975 w/Big M Cabinet
Discussion in 'Member Classifieds' started by fretted friend, Dec 16, 2019.
  1. Relic61
    Relic61 Well-Known Member
    Aug 21, 2013
    490
    478
    Catskill Mnts
    Well, your Master Volume mod 'could be made to appear' to have used the voltage selector hole. Meaning, the amp could be fitted with a Voltage Selector switch (working or dummy) to give the no 'extra' holes look if & when restored.
    Being I don't see the 2 little screw holes that mounted & held the voltage selector in place that should be left visible.. I'd guess that by 1975 the Voltage Selector was forgone & pre-set for our American market as seen on the back of my 1976 JMP 50 watt Master Volume.
    (1976 50 watt Master Volume rear panel without voltage selector)
    (stock JMP photo with voltage selector)
    (your amp below)
    Now I don't have your amp in front of me & I might be wrong but it appears the pre-amp signal is jumpered over to the rear panel Master Volume mod.
    (Your amp with Master Volume mod wire highlighted)
    So it's also my guess that your cleanest sound is going to be found keeping the front panel volumes on or below 4 (All my 4 hole 'non-master volume' JMP's start to get power tube driven tones after passing 4 on the Volumes) & then lowering / adjusting the rear panel Master volume to taste.
    The Volume on 4 is usually pretty loud on these old JMP's.
  2. Sapient
    Sapient Well-Known Member
    Mar 14, 2020
    145
    300
    From one newb to another, welcome. Nice amp!
    Ohhh that was a while ago. Welcome anyway?
  3. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    437
    402
    There are two on eBay from New York, and another '76 in Illinois craigslist for $100 less, in very good condition.
    edit: Appears ALL original. While the two on eBay have had the speakers replaced.
    (how much for shipping I wonder. Scumback would know. ;-)
  4. Sokool
    Sokool New Member
    Feb 25, 2018
    15
    4
    Fort Lauderdale, FL
    My '75 Marshall 50 watt JMP MKII needs 12AX7A tubes, but, they range in price from $10 to $200 each... I want what's best for this awesome classic amp... Ideas, because I have none! Which to choose?
    I just bought the 6550's.
  5. Matthews Guitars
    1,422
    1,806
    Double tap. See below.
  6. Matthews Guitars
    1,422
    1,806
    Just get the Mullard reissues for V1 and V3. For V2, get a JJ 12AX7A. With ONE exception, you don't want to run a Russian made 12AX7 in V2 because the cathode follower circuit it has will cause the tube to fail due to the high voltage applied to the grid. That one Russian exception is the Sovtek 12AX7WB. It's made for the job and it's OK.
    If you want to play around with older tubes, vintage/NOS/tested pulls, whatever, I can't make any recommendations there. Too many variables, too few that I've actually got any experience with.
