Jmp-50 Super Lead Plexy(clone)
Discussion in 'Building the Classics' started by DZagorac, Mar 12, 2018.
  1. DZagorac
    DZagorac New Member
    Mar 12, 2018
    4
    Hi guys, what you think about this??
    SPEC:
    point to point
    with master volumen at back
    3xECC83, 2xEL34
    capacitors: JJ and Malory 150
    resistors carbon roll
    potentiometers are Alpha
    ceramic bases for tubes
    This cost 1000$, just head.. 1.jpg 2.jpg 3.jpg 4.jpg 1.jpg 2.jpg 3.jpg 4.jpg 2.jpg
    el_bastardo likes this.
  2. Rick Lee
    Rick Lee Active Member
    Jan 24, 2012
    397
    128
    AZ
    Can't tell brand of tubes or trannies. Barring Merren trannies and NOS tubes, I'd say $1000 is about right, maybe high side. Wires could be a little shorter, but otherwise pretty clean. Nothing in there looks exotic and you could build that for a little less. So you're paying a little for labor.
  3. ampmadscientist
    8,127
    3,180
    It's not the "cleanest" building I have seen....
    But it takes a lot of practice to build an amp clean and neatly, like the factory. That is not easy either.
  4. el_bastardo
    el_bastardo Well-Known Member
    Apr 26, 2017
    3,723
    3,476
    If it sounds like it should then it's easily worth $1000.
  5. stickyfinger
    stickyfinger Active Member
    Nov 11, 2010
    377
    106
  6. DZagorac
    DZagorac New Member
    Mar 12, 2018
    4
    Thank you all guys, I will buy some vintage amp for 1 500$..
