jmp 2203 speaker outs?
Discussion in 'Marshall Amps' started by tritone, Feb 10, 2011.
  1. tritone
    tritone New Member
    Feb 10, 2011
    2
    Melbourne, Australia
    Hi,
    I recently bought my first real amp. A 1978 Marshall JMP. On the back it has two speaker outputs but they are not labelled. Which one do I use and what is the second for? The only mod to this amp is an ohm selector switch in case that makes a difference to my question.
  2. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    7,726
    4,599
    Got any pic's?
  3. tritone
    tritone New Member
    Feb 10, 2011
    2
    i'll have to take some tomorrow and put them up.
  4. charveldan
    Jan 31, 2010
    7,726
    4,599
    I've got two 78's, they both have 4 speaker outs as the amps made for the US had to in the 70's to be UL rated for insurance purposes.
    Your amp will either have 2 or 4 speaker outs as JMP's had no loop, unless your was modded, that's why i asked for pic's.
    It's important that you match the cab's impedance to the amp.
  5. Clammy
    Clammy Well-Known Member
    Feb 24, 2010
    2,247
    1,614
    The 2 speaker outputs are wired in parallel. You can use 1 or 2 cabinets (if using 2, make sure they're both the SAME impedance). Set the impedance selector to match to total impedance. For example, if using a single 4, 8 or 16 ohm cab, set the selector to match the cab's impedance. If using 2 8 ohm cabs, the selector needs to be set to 4 ohms, if using 2 16 ohm cabs, the selector needs to be set to 8 ohms.
    Cheers!
    :dude::dude::dude:
  6. Frankie
    Frankie Well-Known Member
    Sep 8, 2007
    6,834
    3,689
    Tampa, FL
    If you're only using one cab either output works fine. The one closest to the impedance selector is wired up directly to the OT, so being anal retentive about shit like that, I normally use that plug just in case some bus wire wants to burn up on me and take out my OT by using the other jack.
  7. Frankie
    Sep 8, 2007
    6,834
    3,689
    Tampa, FL
    Dave's livin' the American dream over there in the UK.
    Hot chick? Check.
    Rock & Roll band? Check.
    Party liquor? Check.
    Now all you need is an opium den.
