Jmp-1h Tone Stack
Discussion in 'Marshall Amps' started by indeedido, Aug 17, 2016.
  1. indeedido
    indeedido Active Member
    Jul 2, 2009
    694
    186
    Where the wind comes sweeping down the plains...
    I'm thinking about picking up a JMP-1H and I'm curious what owners think about not having a mid control. I'm fond of the mid control and presence and I'm curious if you guys that own one ever miss them. Yeah there's outboard gear you can add to it, but I'm curious about plug and play aspect.
  2. crossroadsnyc
    Feb 5, 2009
    20,338
    18,589
    Not the same amp, but the only thing I really miss having on my C5 is a presence control.
    The Ozzk and tonetrain like this.
  3. pedecamp
    13,642
    9,943
    I suggest you look at the JVM1, its got a little more going than the JMP1 and sounds fantastic.
  4. indeedido
    Jul 2, 2009
    694
    186
    I thought about the JVM1, but I'm thinking about selling my YJM100 and buying a Mini Jubilee Head and a JMP1 for my more classic tones.
  5. schwa
    schwa Active Member
    Sep 2, 2010
    316
    164
    Boston
    I have a JMP1 head, and it's my favorite 1 watter. The gain curve is awesome, a bit gainier than a proper JMP, but similar. The boost channel is also very usable and a nice feature for "modded JMP" sounds.
    If there's a liability on this amp it is the EQ. The mids. are pretty forward, and the bass is a little shy. In fact, bringing the bass up also increases the mids.
    There are ways around it. First of all, if you play through a 4x12, it balances out. It's not an accident that Marshall demoed these with 4x12's. I don't have a 4x12, but speaker choice can compensate - the scooped character of the T75 helps vs. a middy speaker like a greenback. I also am using a parametric EQ to boost the bass and cut the mids.
    I think the JMP1 is an awesome amp - the best solution I've found for getting NMV Marshall sounds at home. The JTM1 and Offset 1 watters are also very nice amps, and don't have the EQ issue with small cabs. I don't like their gain curve as much though.
    indeedido likes this.
  6. indeedido
    Jul 2, 2009
    694
    186
    Thanks, just what I was looking for.
