Jmp-1 Preamp
Discussion in 'Marshall Amps' started by Seventh Son, Aug 17, 2017.
Tags:
  1. Seventh Son
    Seventh Son Well-Known Member
    Jul 24, 2014
    666
    694
    Naples, Florida
    I'm trying to find out whether the JMP-1 preamp has special effects built in, but there isn't much info on that on the Internet. If yes, what effects does it come with?
  2. marshallmellowed
    Jun 26, 2009
    3,476
    3,972
    No, it's just a programmable preamp with an Fx loop.
    Dogs of Doom likes this.
  3. Waldog
    Waldog Member
    Jul 3, 2017
    46
    18
    Definitely no built in FX. The effects unit that goes hand in hand with the JMP-1 is the JFX-1. It's also a rack mounted unit and they're unreal. None of the fancy unusable effects that you get with a lot of effects units. Just a good collection of very nice usable effects. From memory it even had an analog switching jack built in. This means you can program it to switch channels on a non midi amp. A very handy upgrade if you have an older amp.
  4. JacksonCharvelAddict
    Mar 4, 2016
    1,699
    1,718
    The only effect the JMP-1 has is female orgasm. They are seriously beastly sounding. I love the tone Megadeth got when they used it briefly in the 90's. Something about the way it handled the palm mutes is magic.
