JMP-1 no leds or number display working.
Discussion in 'Marshall Amps' started by Waldog, Jun 14, 2019.
  1. Waldog
    Waldog Member
    Jul 3, 2017
    44
    16
    Hi all,
    I’m looking to buy a JMP-1 but the buyer says that none of the leds light up including the number displays. Sometimes they light up when it’s first turned on but then they stop working. Other than this it works fine and the price is right.
    Has anyone come across this before? I’m hoping to open it up and find a dry solder joint somewhere that’s an easy fix.
  2. ampmadscientist
    12,680
    6,566
    Left Coast
    It could be broken solder connections, cracked circuit board, failed power supplies.
    Be careful how much you pay for broken gear.
    The components are static sensitive, one spark of static and it blows the processor.
    Special anti-static soldering equipment is required to work on gear like this.
    Also: replace the CMOS battery. Install a battery holder on the board.
    But this can also damage the circuit tracks if you don't have the equipment and the skills to work on PC boards.
  3. Micky
    Apr 29, 2010
    20,101
    16,121
    Vermont
    Have you tried a complete hard reset?
    Also might be the battery is dead...
  4. anitoli
    anitoli Well-Known Member
    6,188
    6,609
    Don't fry that EPROM...................
  5. peterplexi
    peterplexi Member
    Mar 13, 2011
    106
    22
    Hey guys! Do yourself a favor and send it to Tommy Folkesson and have him do the "Eternal Classic Jmp-1" mod. You will not be disappointed. He would obviously fix the issue as well without a problem.
    Cheers!
