JCM900 Missing Reverb.
Discussion in 'The Workbench' started by Brian Jones, Nov 21, 2019.
  1. Brian Jones
    Brian Jones New Member
    May 23, 2019
    4
    4
    Hi folks,
    I have a JCM900 that the reverb has quit working on. I am looking for suggestions of any common issues before I commence surgery.
    Brian.
  2. South Park
    893
    609
    Thar is a digital chip related problem.
  3. Jon C
    Jon C Well-Known Member
    May 29, 2017
    1,337
    2,291
    Wa State
    Solid State ……Yes
    Digital … No
    It’s a ‘90s Amp
    900s have a Reverb Tank
  4. Lance Chambers
    Jun 23, 2019
    714
    985
    The Land That Time Forgot
    What model?:hmm:
    My JCM 900 4100R has a tank.
  5. Gunner64
    Nov 16, 2013
    4,971
    5,641
    Midwest, USA
    The in and out rca jacks and plugs at the tank can be the source of the problem. That's where I'd look first.
  6. ampmadscientist
    14,277
    8,090
    Brian Jones, of Rolling Stones? Are you the Ghost of rockstars past?
    Turn up the reverb control, turn up the master volume shake the amp around and bump it against the cabinet.
    Do you hear the springs rattling?
    (should hear this noise from the springs if the reverb return is working)
  7. ampmadscientist
    14,277
    8,090
    Turn on the amp.
    Turn up the reverb and master volume controls.
    Un-plug the reverb return from the reverb tank.
    Touch just the tip of the reverb return cable RCA plug with your finger.
    When you touch just the tip of the reverb return cable, you should hear a buzzing noise from the amp.
    Does this happen as above?
  8. ampmadscientist
    14,277
    8,090
    Take the reverb tank out of the amp.
    Look inside the reverb tank where the wire are soldered to the RCA jacks.
    Is there a broken wire right at one of the RCA jacks inside the reverb tank?
    This is where the wires break sometimes inside the reverb tank.
  9. ampmadscientist
    14,277
    8,090
    There is actually dual analog op amps that have an A/B switch built into the op amp.
    The A/B switching is controlled by a voltage from the switching circuit.
    Sometimes the op amps with A/B switching do go bad.
    But look inside the reverb tank first for a broken wire at the RCA jack.
  10. Gutch220
    Gutch220 Well-Known Member
    Feb 19, 2018
    680
    477
    NJ
    let us know if you can isolate the issue and fix it.
    If not, i have an old accutronics tank from 1990 that came from a 4100 that works that you can have.
    ....but new replacement tanks are easy to find.
    get a multi-meter and check continuity, that's a good place to start
