JCM800 Bright cap ,......which one is it ,.. anyone did a clip job ?
Discussion in 'Marshall Amps' started by Kelia, Mar 29, 2020.
  1. Kelia
    Kelia Well-Known Member
    Feb 26, 2018
    851
    799
    Hi guys ,.....my JCM800 doesn't have that ice picky awfull sound on lower volumes that I've heard on other amps including late JMP's but I've also read that clipping it makes the amp sound rounder and more pedal friendly ,..some guys put it back in so the best way for me
    is to clip it and see if I like it more but the problem is that there's three of them
    and I don't know whcih one to clip ?
    Anyone hear playing witout it ?
    Thanks !
  2. Matthews Guitars
    1,799
    2,380
    It's the one on the back of the volume control, not the one strapped across the resistor.
    Rather than clip it, unsolder one lead and let it hang free. You can then just resolder it if you liked it better as it was.
  3. ampmadscientist
    17,852
    11,888
    Kelia likes this.
  4. Kelia
    Feb 26, 2018
    851
    799
    Wow !,......Ask and you shall receive !!........Thanks guys,....appreciate !
    Will try this.
  5. Seanxk
    Seanxk Well-Known Member
    May 14, 2018
    318
    268
    Turn your Pot to full or off, not good if volume is at 5 and you heat the centre lug as it can heat through to the brush and burn the track.
  6. MarshallDog
    Nov 28, 2010
    13,891
    14,337
    Taintville
    If it does not sound ice picky then leave it. Having no cap at all will make it sound dead. Ive done it on this exact amp but mine was ice picky to start with. I believe I ended up with a 480 or 560 pF in that spot.
  7. Jethro Rocker
    7,905
    9,032
    What about the one strapped across the resistor? Just curious. It's some sort of treble cap, no?
  8. MarshallDog
    Nov 28, 2010
    13,891
    14,337
    Taintville
    I believe thats called the first stage treble peaker. Ive played with that arrangement also and in the end went back to stock.
    neikeel and Jethro Rocker like this.
  9. MarshallDog
    Nov 28, 2010
    13,891
    14,337
    Taintville
    Are you trying to make it sound brighter or less brighter?
    79 2203 likes this.
  10. Jethro Rocker
    7,905
    9,032
    I assume he wants less bright. I wondered about that too but wasn't sure what the treble peaker did
  11. MarshallDog
    Nov 28, 2010
    13,891
    14,337
    Taintville
    If its not ice picky now I’ll bet a pack of TP on it that he wont like it at all with nothing there. 0 pF there makes an amp sound dead IMO and I dont like ice picky at all. I guess he should give it a try if he can solder!?
    neikeel, 79 2203 and Jethro Rocker like this.
  12. Jethro Rocker
    7,905
    9,032
    What does the treble peaker do then? Just curious, I mean I do like how my 4010 cuts. Partly what makes an 800 an 800. Single channel that is. If ice picky can kill some presence I guess
  13. MarshallDog
    Nov 28, 2010
    13,891
    14,337
    Taintville
    I guess it just adds some treble response early on in the amplification process!
  14. coolidge56
    coolidge56 Well-Known Member
    Jan 30, 2019
    623
    1,386
    WA state hinterlands
    Trying to fix a problem that does not exist frequently leads to trouble. A cut finger, you poke out an eye, etc.
  15. Kelia
    Feb 26, 2018
    851
    799
    I just tried it and it sounded like a cranked 1986 without the 800 growl so I put it back in
    and it will stay there ,.it's not ice picky ,........I was just curious and needed to try it.
    Think it's one of the best amp I ever played !.........when I play it ,I hear about every Classic Rock records done in the 80's !
  16. Kelia
    Feb 26, 2018
    851
    799
    Thanks for the input ,............didn't know that .
    Seanxk likes this.
  17. wakjob
    wakjob Well-Known Member
    Dec 29, 2011
    5,367
    3,637
    C-137
    I've said my peace on the brite-cap issue enough...but, I like it stock mainly for the way it helps with reaction to the guitars volume control.
    I modded my 2204 to the moon and back.
    In the end, near stock with just some component upgrades, and it was at its best.
    JDW3, neikeel, 79 2203 and 3 others like this.
  18. Kelia
    Feb 26, 2018
    851
    799
    Curious on what components upgrade you did ?
  19. wakjob
    Dec 29, 2011
    5,367
    3,637
    C-137
    The aforementioned UF4007's.
    And Sozo's replaced all the Wima's.
    That, along with some choice tubes and I was done with it.
    I learned that a 2204 wants to be a 2204...and nothing else.
    johnny q, Bemis and Mitchell Pearrow like this.
  20. Kelia
    Feb 26, 2018
    851
    799
    Thanks wakjob !..........the UF4007's makes the amô feel spongier or what exactly does it do ?
