jcm800 2205 hum
Discussion in 'The Workbench' started by louied, Jan 25, 2020.
  1. louied
    louied Member
    Oct 21, 2008
    40
    5
    My '84 2205 has a constant 120hz hum, regardless of channel 1/2 or knob settings. Otherwise, it sounds great. None of my other amps have this hum on my house power, just this amp. I've swapped tubes and I don't think they are the problem. Any ideas? Or should I just take it to a tech?
  2. ampmadscientist
    15,594
    9,504
    OK take out the phase inverter does the hum stop?
    Do you know which tube is the PI?
    Do you have a volt meter?
  3. louied
    louied Member
    Oct 21, 2008
    40
    5
    Is the PI in v4?
  4. louied
    louied Member
    Oct 21, 2008
    40
    5
    OK, PI is v5. I pulled the tube and fire up the amp. The noise is gone. Yes, I have a volt meter.
  5. ampmadscientist
    15,594
    9,504
    Put V5 back in.
    Take out V1 V2 V3 V4.
    Is the noise still there?
  6. louied
    louied Member
    Oct 21, 2008
    40
    5
    I pulled them individually.
    v1: noise still there
    v2: no noise
    v3: no noise
    v4: noise still there
    v5: no noise
  7. ampmadscientist
    15,594
    9,504
    I'm not getting what I need.
    Pull all the tubes V1 V2 V3 V4 except the PI V5 and tell me if the noise is gone. Yes or no?
  8. Gunner64
    Nov 16, 2013
    5,534
    6,709
    Midwest, USA
    And remember v4 is reverb in this one. (Not trying to get in the way and I'll shut up after this post :)) is the reverb on or off during this humming?
  9. ampmadscientist
    15,594
    9,504
    You made a good point.
    I'm just trying to narrow it down.
    It can be filament, it can be PI, it can be reverb yes...definitely could be the reverb malfunction.
  10. ampmadscientist
    15,594
    9,504
    OK so you know the hum doesn't originate from the power tubes...
    Now step 2
    put the PI back in, and pull the other V1 V2 V3 V4 preamp tubes.
    Now test again.
  11. louied
    louied Member
    Oct 21, 2008
    40
    5
    I pulled v1 v2 v3 v4 and left v5 in. No noise.
    With all preamp tubes in, the reverb knob does not change the hum. It's constant on both normal and boost channels with reverb set to 0 or 10.
  12. ampmadscientist
    15,594
    9,504
    Now install V5, V4 and leave V1 V2 V3 out.
    Re-test and see if the hum comes back.
  13. MickeyJ
    MickeyJ Well-Known Member
    Nov 11, 2019
    747
    433
    if you've both swapped pre-amp tubes, and used the isolation method of finding the noise ( pulling tubes to see which stage the noise is coming from ), and,
    if v4 is the reverb return/ send and return , then, it looks like this is a job for the tech as it appears the problem is associated with v4 as the hum starts when pulling that tube working from the power amp backwards.
  14. louied
    louied Member
    Oct 21, 2008
    40
    5
    With v1 v2 v3 out, no noise.
  15. ampmadscientist
    15,594
    9,504
    OK
    Now V5, V4, V3 in, and V1 V2 removed.
    Did the hum come back?
  16. ampmadscientist
    15,594
    9,504
    Wow, did you get this: Kobe Bryant killed in helicopter crash this very morning.
  17. louied
    louied Member
    Oct 21, 2008
    40
    5
    With v1 v2 out, the hum is back.
  18. louied
    louied Member
    Oct 21, 2008
    40
    5
    Tragic news about Kobe
  19. ampmadscientist
    15,594
    9,504
    V1, V2 out.
    So if you pull V3, the hum goes away.
    And if you install V3, the hum comes back?
    Verify please. Just double check....
    I'm looking at the schematic now...gimme a minute it's early :drunk: time for warm ups.
  20. ampmadscientist
    15,594
    9,504
    I'm shocked and saddened of this news. He was a hero to many.
