Jcm800 2204 Build
Discussion in 'Building the Classics' started by coolidge56, Mar 22, 2019.
  1. FourT6and2
    FourT6and2 Active Member
    Dec 3, 2010
    472
    242
    Thanks!
    I never seem to get much splatter. I just use a good iron and maybe the type of solder and its diameter I use helps? I use Kester 63/37. That and I figure splatter is from outgassing, right? The rosin flux boiling off. So the angle and speed at which you feed solder will affect how much splatter you get. Just my theory, but it seems to work.
    neikeel and coolidge56 like this.
  2. Paul H.
    Paul H. Member
    Nov 4, 2018
    38
    50
    Gone very quiet over here....
    I’ve been watching this thread (from the UK) with real interest.
    Any news?
    Progress?
    Cheers, Paul H.
  3. Filipe Soares
    Mar 8, 2019
    621
    952
    Man! I'm moist!!!
    That boards looks incredible!!!!! AMAZING!!!!
    if by any chance you'll sell some of them, send me a message.
  4. coolidge56
    coolidge56 Well-Known Member
    Jan 30, 2019
    347
    755
    Thanks! I have been distracted by Tele's the past month or so...meet the Texas Twins
    Luna 2003 Highway One Texas, Glendale stainless single cut bridge plate, Gotoh Titanium compensated saddles, DiMarzio Area Hot T and Area T pickups, Gotoh vintage locking tuners, black Fender Bakelite pickguard, Ash body, 12 inch radius fretboard, tall/narrow frets.
    Psycho 2008 Highway One Texas, Glendale stainless single cut bridge plate, Gotoh brass compensated saddles, SD Quarter Pound pickups, Gotoh vintage locking tuners, black Fender Bakelite pickguard, Ash body, 12 inch radius fretboard, tall/narrow frets.
  5. CoyotesGator
    CoyotesGator Well-Known Member
    Jul 31, 2012
    1,882
    1,659
    The Institute for the Very, Very, Very Nervous
    I'll gladly pay for one if you have any left.
    Cheers!
  6. coolidge56
    Jan 30, 2019
    347
    755
    I'll try to get some boards boxed up early this week guys. PM me your mailing address. As a reminder I will ship only to the continental U.S.
    Exojam and CoyotesGator like this.
  7. Exojam
    Exojam Well-Known Member
    May 31, 2017
    617
    395
    Update?
  8. Fender
    Fender Active Member
    Nov 14, 2017
    294
    230
    yeaaah we'd love to see the board mounted and wired in the cab !
  9. Paul H.
    Paul H. Member
    Nov 4, 2018
    38
    50
    +1
    And sound....
  10. Guitar-Rocker
    Mar 5, 2012
    2,746
    2,335
    Indianapolis, Indiana
    I'd gladly pay for one too.
    CoyotesGator likes this.
  11. Exojam
    May 31, 2017
    617
    395
    Can filter caps use only two pin caps as the ones in the below quote?
    I was looking at my build which is a 50 watt plexi and mine are showing 3 pin filter caps, 2 being positive and 1 being hooked to ground.
  12. Exojam
    May 31, 2017
    617
    395
    Did you put together a parts listing?
  13. coolidge56
    Jan 30, 2019
    347
    755
    Technically yes, practically speaking no. A single 50uf film cap rated for 50 watt voltages is quite large physically about 1x2 inches. The cap you are describing is a dual 50uf/50uf cap with a common ground, this is common for electrolytic caps. I'm not sure if anyone makes a dual film cap but a 50uf/50uf film cap rated for these voltages would be quite large and likely too tall to fit within the typical guitar amp chassis.
    On this subject when shopping even for single 50uf film caps, they come in a bunch of different sizes. Older stock typically are larger than newer stock. The length, width, height varies. Sometimes a cap with a higher rated voltage is smaller, another indication of older stock vs newer stock. These film caps continue to shrink in size over time with improved manufacturing methods. So search on 50uf, in a voltage rating range of 500vdc to 900vdc (watch the VAC ratings). Start with the size format that best fits your needs. That could be a higher voltage rated cap in a smaller size, and likely more expensive, vs a larger cap with a lower voltage rating and lower price.
  14. coolidge56
    Jan 30, 2019
    347
    755
    In other news my amp project continues to be on hold due to my day job work has been insane. Likely no time for it until the major holidays later this year.
  15. CoyotesGator
    Jul 31, 2012
    1,882
    1,659
    Such is life.
    If you only knew what my Laboratory looked like, full of life moments.
    Cheers!
  16. Fender
    Nov 14, 2017
    294
    230
  17. coolidge56
    Jan 30, 2019
    347
    755
    I purchased 2 Tele's, 2 banjos, and 1 acoustic the past few months, plus some recording gear...none have been played yet due to work/life insanity (face palm)
  18. Steverino1984
    Steverino1984 New Member
    Sep 6, 2019
    2
    I get it, coolodge56, sometimes important/work/family life precludes (also important) fun/recreation/play life. In my experience, the former generally provides resources for the latter.
    I’m confident no one is more anxious to get back to the guitars, banjos, recording and amp stuff than you!
  19. coolidge56
    Jan 30, 2019
    347
    755
    Here's an update...I just got home from a work trip 20 minutes ago and I'm off again Monday morning for another one. Plus I see the grass needs mowing...and the check engine light came on in my $74k truck on the way home from the airport :pissed: Wait for it...LMAO my life. :run:
    MarshallDog and CoyotesGator like this.
  20. mickeydg5
    23,221
    10,312
    Use burnin oils?
