Jcm800 2204 Build
Discussion in 'Building the Classics' started by coolidge56, Mar 22, 2019.
  1. coolidge56
    coolidge56 Well-Known Member
    Jan 30, 2019
    347
    755
    I purchased my first JCM800 recently the new Studio SC20H. Kind of fell in love with the little 20 watt's tone so for fun I have decided to scratch build a 2204 50 watt.
    The first batch of components arrived lets have a look.
    Mercury Magnetics power transformer P50JM-475.
    Mercury Magnetics output transformer 050JM.
    Mercury Magnetics choke MMC-3H.
    Vishay BC 100,000 hour Polypropylene film filter caps, 5% tolerance.
    Synergy Royal Mustard USA signal caps.
    OHMITE 5W wire wound resistors.
    Film caps continue to shrink in size. I have these drawn on the PCB/turret board and they fit fine.
    Top view
    Side view. The 50 watt power transformer is the same size as a 100 watt.
    Comparing the size of the output transformer, here is a 100 watt on the left vs the 50 watt on the right.
    This will be the first time I have used these Synergy Royal Mustards. Fingers crossed.
    Digi-key misrepresented these TE Connectivity 3W power resistors on their site. I may go with a different brand.
    Next I'll continue work on the CAD for the PCB/turret board.
  2. ampmadscientist
    14,840
    8,705
    What are the 200 volt caps for?
  3. coolidge56
    Jan 30, 2019
    347
    755
    Are you asking about those .68u caps?
    neikeel likes this.
  4. Yugedrums
    Yugedrums Well-Known Member
    May 7, 2015
    344
    263
    South Carolina
    Subscribed. :hmm:
  5. mickeydg5
    23,221
    10,312
    What are all the little black boxes? Mouse traps?
    (Its joke)
  6. coolidge56
    Jan 30, 2019
    347
    755
    When two black holes merge they absorb the gravity waves and sweeten the reverb.
  7. ampmadscientist
    14,840
    8,705
    You have rectangular filter caps?
  8. coolidge56
    Jan 30, 2019
    347
    755
  9. mickeydg5
    23,221
    10,312
    yes, DC-Link capacitors
  10. ampmadscientist
    14,840
    8,705
  11. coolidge56
    Jan 30, 2019
    347
    755
    Yep the future has arrived. The amp basically will never need to be re-capped. If someone played the amp 2 hours a day 5 days a week it will be 200 years before the caps need to be replaced. ESR/ripple is a tiny fraction vs electrolytic. Less ESR less heat. 5% tolerance. Higher voltage rating etc.
    Hgvhgvyvutvy, syscokid and mAx___ like this.
  12. coolidge56
    Jan 30, 2019
    347
    755
    Those look sweet. Sadly I don't see a supplier for them here in the USA.
  13. junk notes
    junk notes Active Member
    Dec 10, 2018
    206
    190
    very cool, 56 ;-). Always nice to see a build populate.
    Yes those caps sound hi-fi in their info. Which is what you probably want in an audiophile build.
  14. coolidge56
    Jan 30, 2019
    347
    755
    First build with film filter caps so we'll see how this turns out tone wise.
  15. ampmadscientist
    14,840
    8,705
    [​IMG] Digikey has 20uF 700 V 105C rated 100000 hours at 70C for $11.20 80uF $32.98
    I like the specs, that sounds like something I could use....
    * lifetime rating of a standard filter cap is typically 5000 hours at rated temperature.
    This cap is supposed to last like 20 times longer.
  16. coolidge56
    Jan 30, 2019
    347
    755
    Link to that cap?
  17. FourT6and2
    FourT6and2 Active Member
    Dec 3, 2010
    472
    242
    Interesting. Looking forward to seeing how this turns out.
  18. ampmadscientist
    14,840
    8,705
    mAx___ likes this.
  19. coolidge56
    Jan 30, 2019
    347
    755
    Turret/PCB first draft.
    Preamp 90 x 330 mm
    Power Supply 100 x 160 mm
    Amadeus91 likes this.
  20. clutch71
    clutch71 Well-Known Member
    Sep 26, 2007
    1,500
    919
    Columbus, Ohio
    In for the build process. Appears your making your own PCB? I'd like to hear more about that.
