Jcm2000 TSL 100
Discussion in 'Marshall Amps' started by Gogo, Jul 16, 2019.
  1. Gogo
    Gogo Member
    Dec 4, 2018
    40
    4
    Hi,
    I have a problem with settings tone for hard rock/rock on my marshall tsl100 head - cabinet Orange 212 V30. Every tone is like metal tone. Somebody help me with settings tone?
  2. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    923
    875
    Guitar? Pickups? Try fiddling with guitar's volume and tone controls?
    Pedals, try using any? Or try not using any?
    Jethro Rocker likes this.
  3. Gogo
    Gogo Member
    Dec 4, 2018
    40
    4
    Prs with humbuckera classic 57 and burstbucker2, and I use volume and tone controls and only booster mxr no more stomp.
  4. The Dose of Harmony
    The Dose of Harmony Well-Known Member
    Nov 21, 2014
    356
    268
    the TSl's are just Mad Animals!
    Full of rage and fury !!!
    to tame the beast change tubes but the two previous post are right too!
    one time i put a Genalex gold lion and V1 and tamed a lot too pussy for me !!
  5. thunderstruck507
    thunderstruck507 Well-Known Member
    Apr 20, 2017
    292
    332
    Use the crunch channel and turn the gain down to below noon. Then roll the treble and presence down.
    Make sure the mid shift button isn't pressed.
  6. Cadorman
    Cadorman Well-Known Member
    Mar 9, 2019
    340
    510
    Shakopee, Minnesota
    You can try putting 5751's in V1 and V2 as well.
    Jethro Rocker and scozz like this.
  7. thunderstruck507
    Apr 20, 2017
    292
    332
    The best tube I had at the time for v1 was a Sovtec.
    Once I got my JCM 800 it had a lot of brightness/harshness I wanted to tame so I tried a new old stock RFT branded as an Ultron and it instantly did what I wanted. It might work very well in the TSL too.
    The mids are weird on the TSL too in my opinion so I tried to keep them as low as I could without it sounding scooped. This was typically just under noon or so if I remember correctly. I think I ran the treble at about 9-10 oclock and used presence to taste to add some highs back...I also added some highs back with my overdrive.
    I use a Black Arts Toneworks Black Forest overdrive which has very powerful bass and treble EQ adjustments. It was a god send for the TSL because it could thicken up the lead channel and the highs helped get a brighter tone that wasn't harsh on the crunch channel.
    scozz and Mitchell Pearrow like this.
  8. scozz
    scozz Well-Known Member
    Jul 20, 2008
    1,268
    2,443
    This ^
    I do this with any medium or high gain amp I buy. To me it makes quite a difference. I’ve also used 12AT7 preamp tubes if a 5751 doesn’t tame the gain quite enough for my likes.
  9. Lance Chambers
    Jun 23, 2019
    204
    253
    Well, it is a metal amp. :band:
    Try using the green channel with an OD in the front.
  10. Gogo
    Gogo Member
    Dec 4, 2018
    40
    4
    I have tubes in V1 TAD 7025 Highgrade WA and V2 Tad ECC83 WA, V3 and V4 Marshall ECC83 tubes, EL34 Marshall stock.
    Yesterday I change V1 on ThungSoul ECC83, hmmm ..... maybe a little better but I want rock tone.
  11. Jethro Rocker
    6,962
    6,675
    The tubes shouldnt matter that much. Dont use any pedals at all to start with. Use channel 2 with tne tone shift OUTas mentioned and set tne gain around 5 and see. What do you mean by rock tones?? Old Scorpions?? Zepplin?? ACDC which is really a crunch type tone??
    You mention only booster mxr no other pedals. Dont use a booster for rock tones unless you mean modern rock old metal.
    I can get decent hard rock (notice I said HARD rock) tones with gain about 7 on channel 2 and it actually cleans up a fair bit as I drop guitar volume down. If gain is around 5 it shoild do it, perhaps even a bit less.
    Have you tried this? What happens??
  12. Lance Chambers
    Jun 23, 2019
    204
    253
    My thoughts exactly! It's a MARSHALL..........famous for rock tones. How can a player not get good rock tones from it? :coffee:
  13. Gogo
    Gogo Member
    Dec 4, 2018
    40
    4
    tone ACDC would be nice:) but I thing not this amp
    my settings
    channel
    OD - bass-4, mid-5, treble-5, gain-4.5, rev-4, pres-3, tone shift out, deep out
    lead - bass-5, mid-6, treble-5, gain-5, rev-4, pres-3, tone shift out, deep out
    clean - bass-5, mid-5.5, treble-4, gain-3, rev-3, pres-3, tone shift out, deep out
    any ideas?
  14. Jethro Rocker
    6,962
    6,675
    ACDC is a crunch to me. Do you find it too much gain at 4.5 on channel 2? Then lower it.
    Try channel 1 with gain near the top too.
    If its still too much then do the pre amp tube change to a lower gain tube like a 12AY7 or AU7.
  15. Gogo
    Gogo Member
    Dec 4, 2018
    40
    4
    thanks
    I'll check tommorow
  16. thunderstruck507
    Apr 20, 2017
    292
    332
    I got great AC/DC tones with the gain on about 3 on channel 2. Then I used a MXR overdrive set as a clean boost (volume up, gain off) to add some bite and sustain.
    If you are playing loud enough you shouldn't even need the boost for that, but I was keeping master volume at 2-3 which while it was loud, it wasn't enough to drive the amp well. My TSL liked to be LOUD before it really started rocking. My 800 is better at low volume surprisingly.
    Jethro Rocker and Lance Chambers like this.
  17. Lance Chambers
    Jun 23, 2019
    204
    253
    How do you like that KK amp? :drool:
  18. Jethro Rocker
    6,962
    6,675
    With the higher gain sounds the TSL sounds excellent at 2 or 3 on channel volumes.
  19. Cadorman
    Mar 9, 2019
    340
    510
    Shakopee, Minnesota
    If he's going for this kind of grind he won't get it out of a TSL without using pedals through the clean channel, or some kind of mods.
  20. Jethro Rocker
    6,962
    6,675
    It should. Lower gain on channel 2 or high gain on channel 1. To me that sounds barely breaking up. Not sure what OP is after as he mentioned hard rock/rock at one point.
    Cadorman likes this.
