JCM2000 TSL 100 and TSL 60 questions
Discussion in 'Marshall Amps' started by Hutch, Aug 20, 2019.
  1. Hutch
    Hutch Active Member
    Oct 11, 2013
    127
    93
    So besides the shared EQ on the OD channels on the TSL 60 does it have the same issues with the effects loops as the TSL 100 and is the voicing the same or are they different. I have a TSL 100 and love the tone but the effects loop sucks period and the FX mix is worthless. thinking of trying the 60 if they are voiced the same.
    Thanks
  2. The Dose of Harmony
    The Dose of Harmony Well-Known Member
    Nov 21, 2014
    407
    317
    The are different the Tsl100 you switch from series / parallel if you put the play with the knob , with the Tsl 60 you only have series if i remember right
    I own both and none of are my cup of tea.
  3. The Dose of Harmony
    Nov 21, 2014
    407
    317
    The fx mix knob should work if you put it at max goes on parallel or in series but it should work, when i said not my cup of tee its because the noise and drop in volume i haven’t play that much with the Tsl60
  4. marshalltsl
    marshalltsl Member
    Apr 6, 2012
    91
    94
    Catalonia
    My '98 TSL100 FX loop boost the guitar signal when you use it. Always has make noise and It colored the sound. After '98 all TSL100 fxloop dropes the guitar signal when you use it and make noise. Just the issues 20 doesn't make noise but if you use effects with vol. Input and vol. Output you can balance perfectly the volumen.
    On the TSL100 the mix knob goes on series if you put It at max.
    Exist a kit to replace clean, crunch, Lead, rear and mother boards to last version.
    The amp sounds pretty the same but It has better switching channels, better VPR (25w mode), much better fxloop, much better emulated line out.
    If you want the best TSL100 I recomend this kit.
  5. Jethro Rocker
    6,988
    6,747
    Yes i set my TSL122 to full up series and adjsut for any volume difference with the fx levels. I usjally leave the loop on all the time so the drop in volume is irrelevant. The extra hum I kill with a noise gate as I llay higher gain and need it anyhow.
    The extra features on the 100 make it well worth it to me and an outstanding sounding amp.
  6. The Dose of Harmony
    Nov 21, 2014
    407
    317
    I already got all my issue 20 boars the crunch ,front and clean channel board i hope i have time at the end pf the month to change them out.
    marshalltsl and Sapphire Sounds like this.
  7. Hutch
    Hutch Active Member
    Oct 11, 2013
    127
    93
    where can you get these boards?
    Thanks
    Sapphire Sounds likes this.
  8. The Dose of Harmony
    Nov 21, 2014
    407
    317
    Antique Electronic Supply
    if you need the numbers of the boards you to order later let me know
  9. Hutch
    Hutch Active Member
    Oct 11, 2013
    127
    93
    Yes please! Thanks
  10. The Dose of Harmony
    Nov 21, 2014
    407
    317
    MSH M-TL10-65-02-01 CLEAN CHANNEL BOARD TSL100
    MSH M-TL10-61-02-00 PRE AMP PCB FOR TSL100
    MSH M-TL10-66-02-01 Crunch CH BOARD TSL100/122
    I am missing the main and rear board i get it later !
    What issue number are you running on your main board?
  11. Hutch
    Hutch Active Member
    Oct 11, 2013
    127
    93
    Im not sure have not pulled it apart according to SN# I believe its a 2008
