JCM 900 FX Return Broken
Discussion in 'The Workbench' started by Ryan Morris, Jan 23, 2020.
  1. Ryan Morris
    Ryan Morris New Member
    Jan 23, 2020
    11
    Hi all,
    I have a JCM 900 4100 and the FX return is not working. I can get a signal out of the send just fine, but if i try to put any signal into the FX return, I get nothing. If I bridge the send and return with a patch cable, when I crank the master volume I get a very low volume, oversaturated signal coming through.
    Things I've checked:
    all tubes work fine
    jacks aren't corroded or broken
    the FX jacks and the FX pot are soldered fine
    the FX pot works (I checked with an ohmmeter)
    If I have a patch cable bridging the FX loop, there is no signal or even any voltage drop between the tip and sleeve connecters of the return jack at all.
    Does anyone have any tips for troubleshooting, or what could be the cause of the problem?
  2. Lance Chambers
    Jun 23, 2019
    910
    1,309
    The Land That Time Forgot
    Make sure the "Level" control is set to zero for pedals, middle (5) if jumping & right (8-10) for racks.
    Do you get a signal from guitar straight into FX Return?
  3. ampmadscientist
    15,431
    9,299
    Check and see if IC 7 is getting hot.
    Is IC 7 in a socket?
    Check Pin 8 of IC7 to verify +15 volts DC.
    Check pin 4 of IC7 to verify minus 15 volts DC.
    The schematic is here I think...
    https://drtube.com/schematics/marshall/cd0189-iss7-0349.pdf
  4. Ryan Morris
    Jan 23, 2020
    11
    I tried going straight into the return, no sound
  5. Lance Chambers
    Jun 23, 2019
    910
    1,309
    Oh, btw.........check all cables for continuity where applicable.
    :hmm:
  6. Ryan Morris
    Jan 23, 2020
    11
    IC7 is fine, voltages are good
  7. Lance Chambers
    Jun 23, 2019
    910
    1,309
    Also check the pots with your Ohm meter. They should fluctuate while turning the dials.
    :hmm:
  8. Ryan Morris
    Jan 23, 2020
    11
    I have, all the pots are good
    Lance Chambers likes this.
  9. ampmadscientist
    15,431
    9,299
    Oh sorry shit I was wrong. :wallbash:
    IC 7 is the reverb not effects.
    Reverb return is IC5 a TLO72 op amp.
    Is IC 5 getting hot?
    Is it in a socket? :lol:
    Pin 8 is +15 volts DC
    Pin 4 is minus 15 volts DC.
  10. Ryan Morris
    Jan 23, 2020
    11
    Just checked all the IC's, they're all getting the right voltages. None of them are in sockets, they're all soldered on.
  11. ampmadscientist
    15,431
    9,299
    Replace V2 preamp tube.
    Check V2 R16 should be 2K2.
    Check V2 R3 should be 100K.
  12. ampmadscientist
    15,431
    9,299
    Check IC5 pin 1 for DC voltage. Should be 0 volts or close to it...
  13. Ryan Morris
    Jan 23, 2020
    11
    R16 and R3 are fine, I'v already tried swapping V2.
    I'm currently not getting any signal at Rd, which is what sends the return signal from the FX PCB to the PCB with the valves, so I'm assuming that the problem is occurring at the return circuit BEFORE it gets sent over to the main PCB, right?
  14. ampmadscientist
    15,431
    9,299
    Is there signal on pin 1 of IC5?
    Is there DC on pin one of IC 5?
    This is the TLO72 op amp.
  15. Ryan Morris
    Jan 23, 2020
    11
    IC5 pin 1 has about 10mV
    R2 on the FX board I'm reading as a short (it's labled as 3.3k)! Is that supposed to happen, or is that indicative of a bad resistor? I can't measure the true impedance without taking it off the board
  16. ampmadscientist
    15,431
    9,299
    Resistors can't short.
    It's the other components in the circuit that is giving a short reading.
  17. ampmadscientist
    15,431
    9,299
    Go ahead and replace IC5. Put a socket on the board.
