JCM 800 ,JCM 900, SL-X ,AMP MODIFICATION
Discussion in 'The Workbench' started by Exotic, Nov 30, 2019.
  1. ampmadscientist
    16,666
    10,557
    I leave the diode clipping in the boost channel and I take out the diodes in the clean channel.
    The clean channel won't be really clean until you take the diodes out.
    The effects loop doesn't really match USA effects pedals, so I change the levels in the loop.
    EQ might work better in the loop instead of the front end.
    But if you take the diodes out, then the EQ works OK in the front end.
  2. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    1,186
    937
    Saginaw MI
    The only mod to a 900...seriously...is gutting it and starting over with the design you desire.
    You can subtly tweak some things, but no OMG mods exist with out total reconstruction.
    Been there, done that.
