JCM 800 ,JCM 900, SL-X ,AMP MODIFICATION
Discussion in 'The Workbench' started by Exotic, Nov 30, 2019.
  1. Exotic
    Exotic Active Member
    Sep 3, 2018
    333
    149
    i just ordered jcm 900 4500 high gain dual reverb from ebay ,mostly because my jcm 800 2210 is in the shop ,and i have become a tone chaser and want to compare them ,but i'm wondering if maybe i should have gotten the sl-x . does anyone know some differences in these 3 amps? as far as crunch . and does anyone know how do they modify marshalls so they become crunchier ?
    https://www.ebay.com/itm/Marshall-J...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
  2. South Park
    1,260
    939
    I prefer the jcm 800 the right amount of gain and tone . Easy to mod easy to repair . Old Skool
  3. Crikey
    Crikey Well-Known Member
    Feb 16, 2019
    320
    461
    I run my 800 2210 with my 4100dr and it freakin rocks.
  4. Crikey
    Feb 16, 2019
    320
    461
    Both 800 and 900 have their own qualities.
  5. Exotic
    Sep 3, 2018
    333
    149
    both heads at once?
    do u think it's worth it to add another preamp tube for more gain ?
    costs alot doesn't it?
  6. Exotic
    Sep 3, 2018
    333
    149
    is this only for older amps ? or can it be done to jcm 900's also ?
  7. Exotic
    Sep 3, 2018
    333
    149
    so the jmc 900's get more gain from diodes ? can u remove the diodes and add a preamp tube for more gain ,how much does it cost?
  8. South Park
    1,260
    939
    The diodes are for clipping the signal no gain . Adding tubes is not something you want to take on . Just add pedals and call it good
  9. Crikey
    Feb 16, 2019
    320
    461
    I run AB and A or B. It is a fat freakin sound. For my ears I see no need for another gain tube. Both the 2210 and 900 have more than enough IMO.
  10. Exotic
    Sep 3, 2018
    333
    149
    whats the deal with the ohm switch on a jcm 900 ? how do u use it to avoid blowing up ur amp and can u run a stack ,can u run 2 cabs 8 ohms each? seems to be different than on the jcm 800's
  11. Exotic
    Sep 3, 2018
    333
    149
    and if the amp is on low power setting(25 watts) does it change the impedence? when u take out 2 tubes on a jcm 800 2210 (100 watt amp)it cuts the impedence in half .
  12. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    602
    450
    4500 head is 8 or 16 ohms. You can use one 16 ohm cab, or one 8 ohm cab, or two 16 ohm cabs.
    The confusing label is because the combo versions switch from 4 to 8 ohms.
    The combos and heads have the same output transformer which has 4, 8, and 16 ohm taps -- it's just a matter of which two wires are connected to the switch. So you could rewire it to switch between 4 and 8 like the combo if you want to use two 8 ohm cabs ( two 8 ohm cabs is a 4 ohm total load).
    Edit: if you want to run two 8 ohm cabs but don't want to mod the amp, you could use a series junction box or a series cable to connect the cabs in series for a total load of 16 ohms.
  13. RLW59
    Nov 30, 2017
    602
    450
    The power setting switches between normal pentode mode and triode mode.
    Both output tubes operate in both modes -- it doesn't turn either of them "off". So impedance is the same in both power settings.
  14. RLW59
    Nov 30, 2017
    602
    450
    delete
  15. ampmadscientist
    14,957
    8,785
    No
    No
  16. tschrama
    tschrama Well-Known Member
    May 15, 2010
    1,066
    380
    Netherlands
  17. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    1,736
    1,473
    Why not just get a JVM ?
  18. Ken Underwood
    Oct 16, 2013
    373
    1,031
    I rest my bloody case, amptechsovernight.com
  19. BftGibson
    BftGibson Well-Known Member
    May 28, 2018
    1,294
    3,238
    Good amp. Just get the volume up.
  20. Exotic
    Sep 3, 2018
    333
    149
    THIS ALL SOUNDS PRETTY GOOD ,i can get a cab link .
    i can try out the 25 watt mode see how that go's .
    wondering if the diode clipping is going to get along with my mxr 6 band graphic eq ,and a mxr phase 90 and a cry baby wah . should sound great with my speakers ,jbl d120f's , evh speaker , greenback reissue , g12t-75's , marshall vintage ,and avt speakers .
