JCM 800 2205
Discussion in 'Marshall Amps' started by WoodandBread1, Jul 15, 2019.
  1. WoodandBread1
    WoodandBread1 New Member
    Jul 15, 2019
    2
    Good morning,
    Looking for a little help. I have a 1986 Marshall JCM 800 2205, the 50 watt head. I haven't played it in a few years and looking to sell it. But The gain/boost channel is not boosting or gaining at all. I've checked the pre amp tubes, and the power tubes and they look fine. I've also swapped them around to try different tube positions. But still the boost channel is producing nothing. Any clues as to what might be going on?
  2. Adrian R
    Adrian R Well-Known Member
    Jan 28, 2009
    6,149
    4,160
    Far North Chicago Burbs'
    Not sure, but I'll give ya $100.00 for it right now as is! Lol Start swapping 'known good' preamp tubes. Just because their lit means really nothing. Guitar + amp no pedals. Eliminate foot switch and switch manually (if you can)...Start simple, look for the obvious.
  3. Gunner64
    Gunner64 Well-Known Member
    Nov 16, 2013
    4,637
    5,009
    Midwest, USA
    Clean the pots and tube sockets with deoxit..if that doesn't do it reflow the pot to pcb solder connections. My 87 had a broken solder joint on one of the pots..not sure which one it was..but reflowing the joints where the pots attach to the board solved the problem. My boost channel was weak, had little or no overdrive..and the normal channel and boost channel controls changed the tone of both channels no matter which channel was selected..reflowed the pot connections and it roared again.
  4. Mitchell Pearrow
    6,944
    9,509
    First off:cheers: :welcome: To the forum
    WoodandBread1 likes this.
  5. marshallmellowed
    Jun 26, 2009
    2,931
    2,554
    If I'm remembering correctly, the boost function can only be selected via footswitch. If this is the case, I'd look at the footswitch or the footswitch jack first. A faulty footswitch or dirty footswitch jack would prevent the boost function from engaging.
  6. Gunner64
    Nov 16, 2013
    4,637
    5,009
    Midwest, USA
    You are correct. And thats a good question. The boost channel on mine can only be engaged via the footswitch. As soon as you plug the footswitch in the boost channel engages and the led illuminates..so expanding on that, the op never really said that he even had the footswitch plugged in...no footswitch plugged in, no boost channel...it may be as simple as that.
  7. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    10,825
    9,105
    Taintville
    Welcome aboard new MF’r and good luck fixing and selling her!!
  8. WoodandBread1
    Jul 15, 2019
    2
    Sorry i forgot to mention i do have a footswitch to change between the channels. When it is plugged in the boost channel indicator is on. I ordered some deoxit from amazon today, to try that solution thanks to Gunner64 for that.
    But i have a Gibson V plugged straight into the head, and then the footswitch by itself connected to the input in the back of the head for the footswitch port. The clean channel works well, clean at low volume and then breaks up nice and dirty when the volume is cranked. Just low volume and no distortion on the boost channel.
