Jcm 800 2204 - 80's Metal.
Discussion in 'Marshall Amps' started by Neil Skene, Sep 9, 2018.
  1. Neil Skene
    Neil Skene Well-Known Member
    Oct 3, 2011
    523
    598
    Australia
    Had a chance to record a bit more with this amp, The bottom end is not as crushing as my 2203 but I usually have to cut the low end of the guitar tracks anyway.
    No bass guitar as usual here.
    I couldn't get the timing right at the start like the real song so just put it in time with the 4/4 click track. Hope every one can handle that :)
    I used a CM-2 overdrive on this but also used an MXR 10 band as a boost just on the intro instead of the CM-2. Im going to experiment a little more with the 10 band as a boost into the front end as I think it was a little less noisy, but that may just be because I got less distortion from it than the OD, which was volume cranked plus gain on half as well.
    Wish I had time to set up the V30 cab as well and compare to the G12T 75's.
    The V30's to me sound like I am using more gain when compared to the 75's which is just what I would have wanted here.
    The drums take ages to write and mix but I am getting a bit faster at it.
  2. texhex
    texhex Active Member
    Feb 1, 2016
    212
    240
  3. dslman
    dslman Well-Known Member
    Apr 15, 2012
    2,525
    973
    Sounds good! I have a CM-2 also, it's a sleeper that one day will be worth more, and be hard to find.
    If you can't get an amp to sound good with the CM-2 then somethings wrong.
    Wow , you have a 2204 and 2203? That's KOOL!
    Neil Skene likes this.
  4. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    961
    631
    Saginaw MI
    Damn...been on the fence about building a 2204 for ever...may really have to do it now.
    That was a good clip.
  5. Neil Skene
    Oct 3, 2011
    523
    598
    Australia
    I have a bad Monkey USA as well but I like the CM-2 more because it has more output with the gain on zero.
    My 2203 is a JMP 1977.
  6. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    1,062
    1,593
    Floating above Dallas in Marshall Heaven
    Sounds great!
    I spent some time at a buddies slamming some early Metallica through an Elmwood M60 and a JMP 2203. The Elmwood had much more tone shaping tools to bring the crushing thump but I preferred the 2203 for pure tone.
    Russ
  7. dslman
    Apr 15, 2012
    2,525
    973
    i USE TO HAVE A jmp 2203, I think it was one of the first 2 vertical hollers.
  8. Neil Skene
    Oct 3, 2011
    523
    598
    Australia
    Thanks.
    I burnt up a lot of time on the drums when I probably should have done another track with the OD gain a little lower but time goes so fast when you aren't working.
  9. Neil Skene
    Oct 3, 2011
    523
    598
    Australia
    Thanks.
    Marshalls need a bit of help to do the metal thing, but they do it well with a bit of a push.
    solarburnDSL50 likes this.
  10. Seventh Son
    Seventh Son Well-Known Member
    Jul 24, 2014
    486
    474
    Naples, Florida
    Me + 80’s metal = a match made in heaven
  11. Seventh Son
    Jul 24, 2014
    486
    474
    Naples, Florida
    Here’s my contribution. The best metal sound I have ever heard. It took me years to get the formula just right.
  12. Neil Skene
    Oct 3, 2011
    523
    598
    Australia
    Now I have to wait till tomorrow afternoon to hear it properly when I get home.
  13. Matt_Krush
    Dec 14, 2015
    961
    631
    Saginaw MI
    ^^ And what is that formula?
  14. Seventh Son
    Jul 24, 2014
    486
    474
    Naples, Florida
    ^^^This is a quote from one of my posts on the Tone Zone—>Recording Thread.
  15. Neil Skene
    Oct 3, 2011
    523
    598
    Australia
    Had a listen on my monitors now.
    Pretty smooth, I like it.
  16. Seventh Son
    Jul 24, 2014
    486
    474
    Naples, Florida
    Thank you.
  17. LyseFar
    LyseFar Member
    Jun 26, 2018
    59
    59
    Thanks for the clip - May I ask which guitars / mics are used?
  18. solarburnDSL50
    Aug 8, 2008
    15,092
    7,877
    Wetville
    Fuuuuuck.:applause:
  19. Neil Skene
    Oct 3, 2011
    523
    598
    Australia
    LOL.
  20. Neil Skene
    Oct 3, 2011
    523
    598
    Australia
    Hi, no problem.
    The audio chain went like this.
    Fender strat with Seymour Duncan sh10, hardwire CM-2, JCM800, G12T75, SM57, RME Fireface, Pro tools, Marshall amp forum :)
    KraftyBob and Mitchell Pearrow like this.
