Jcm 2000 Tsl 122 Bias Help
Discussion in 'The Workbench' started by Sapphire Sounds, Apr 13, 2019.
  1. Sapphire Sounds
    Sapphire Sounds Member
    Apr 1, 2019
    43
    21
    Hey later tonight I want to get into my 1999 TSL and check the bias for any adjustments then replace all the tubes.. I have a multimeter and a set of matched power tubes for the amp. I will check youtube out later and browse this forum.
    However the preamp tubes I got with them seem smaller than what I remember being inside the amp, are they okay to use?
  2. Gunner64
    Gunner64 Well-Known Member
    Nov 16, 2013
    4,606
    4,973
    Midwest, USA
    Ecc83/12ax7 are whats pictured and whats in your amp.
    Sapphire Sounds likes this.
  3. ampmadscientist
    12,675
    6,566
    Left Coast
    From where I sit, those tubes look huge.
  4. Sapphire Sounds
    Apr 1, 2019
    43
    21
    Okay I just searched ecc83s and read up, apparently they are nearly the same product.. I dont know my shit yet with amplification. Heres a pic of my Marshall, I'm a stranger to electric land
    Dont they? I thought maybe the preamp tubes were maybe extra small instead but the power tubes are in full chungus sized boxes...
  5. Jon C
    Jon C Well-Known Member
    May 29, 2017
    1,091
    1,806
    Wa State
    Love It !!
  6. Sapphire Sounds
    Apr 1, 2019
    43
    21
    I caught a break and popped the amp up on a table took the back off and popped out the dead power tube and one of the pre amp tubes to see the size comparison
    Haha this amp runs on 4 big chungus tubes and 4 little Debbie's
    How do I get the metal cylinder off the pre amp tube on the far side?
  7. Sapphire Sounds
    Apr 1, 2019
    43
    21
    Update got the sheild off the preamp tube, just turned it pushing up a bit and it sprung out. So is that last socket called the V1 or first gain stage?
  8. Jon C
    May 29, 2017
    1,091
    1,806
    Wa State
    Susceptible to RFI .. shield helps and the spring help reduce microphonic chance …… YMMV
  9. ampmadscientist
    12,675
    6,566
    Left Coast
    It may help to turn the amp upside down, so you can see the pin locations on the sockets.
    The shield is a bayonet attachment.
    Push down lightly and turn counterclockwise to remove the shield.
    Push down lightly and turn clockwise to install the shield.
    The socket which is closest to the input jack is V1, which "is" the first gain stage.
  10. Sapphire Sounds
    Apr 1, 2019
    43
    21
    Hey yall now I can get to it, should I pop all the tubes in and power it onto standby- warm up?
    Heres the old tubes couldnt believe I smashed the last one I took out on the speaker magnet, oh well. The power section was Svetlana EL34 9916 with one labeled 9920. The preamp section is unbranded tubes, 2 of them went microphonic.
    Ill keep the amp somewhere I can get to those metal pins with my multimeter while I shave a pencil into a flathead for the bias adjustments... I have never done this stuff before
  11. Sapphire Sounds
    Apr 1, 2019
    43
    21
    I got the amp used for short money and for a few weeks it would blow the HT fuse consistently but I would just power down and replace the 1 amp fuse to play it while it was still hot. The issue actually went away completely after like 5 fuses for months and it only blew the HT fuse once again, since then its been stable which surprised me. The preamp tube went microphonic so I swapped it and the dead powertube with some from my Blackstar but I put those back a week or two ago so I could retube and bias the Marshall. If my TSL 122 ends up showing that it has a shitty PCB I dont know how I would go about modding it if that hasnt already been done. The issue 20 PCB boards for TSL amps are uncommon to find for sale now.
    Im not planning on looking at the boards in mine yet as I will give it a chance to prove its stability with a proper set of new tubes and bias adjustment.
    Do I pop the new tubes in and let the amp warm up on standby? I guess I can only use my multimeter to check the bias pins when tubes are warm?
  12. Sapphire Sounds
    Apr 1, 2019
    43
    21
    V1 (Blank)
    V2 18H0
    V3 & V4 are both 14D0
    I dont know if the lettering means anything but thats what I went with for the preamp section..
  13. Sapphire Sounds
    Apr 1, 2019
    43
    21
    So I put those 10G8 ones in the second and fourth power tube sockets
    The 10H8 V tube is in the first, and 18H0 the third socket.
    Going to power on and keep the amp in standby warm up for a bit and look for the values I need to set on the two halves...
    Am I doing okay?
  14. Dogs of Doom
    18,612
    17,884
    yep, try 78mv each side. Each side will push/pull on the other side, so, when you go up on 1 side, it'll pull the other side down. So, you'll have to teeter-totter them back & forth.
  15. Sapphire Sounds
    Apr 1, 2019
    43
    21
    Okay cool im going to warm up and make another wooden tool for the plastic part there thanks
  16. Dogs of Doom
    18,612
    17,884
    I bought me a set of these, because they hook/clip onto the bias wires.
    makes it easier. Just clip the black on the center, then move the red one from side to side to test...
  17. Sapphire Sounds
    Apr 1, 2019
    43
    21
    Yeah I like that more than these alligator clips for sure.. I'll look for a set and a multimeter that can actually read mV... Is there a setting I could use on this one I have already?
  18. Dogs of Doom
    18,612
    17,884
    try 200mA (DC) on yours...
  19. ampmadscientist
    12,675
    6,566
    Left Coast
    "I got the amp used for short money and for a few weeks it would blow the HT fuse consistently but I would just power down and replace the 1 amp fuse to play it while it was still hot. The issue actually went away completely after like 5 fuses for months and it only blew the HT fuse once again, since then its been stable which surprised me."
    Sounds like this amp may have serious problems and you shouldn't put tubes into it until you test and solve the issues.
    "Im not planning on looking at the boards in mine yet as I will give it a chance to prove its stability with a proper set of new tubes and bias adjustment."
    You measure and prove the stability without any tubes installed, or else the new tubes may just burn up...you are doing this the wrong way.
    "...The 10H8 V tube is in the first, and 18H0 the third socket...."
    Don't ever put mismatched tubes into this amp.
    All the tubes should be EL34, and all the tubes should be a matched set.
    Get 4 tubes that match, test the amp bias stability FIRST, repair any issues, install the tubes LAST.
    Stop what you are doing. Get with the program.
    Measure and repair the board FIRST.
    If there is a problem with the board, or the bias stability you need to address that FIRST.
    DO NOT do this with the tubes installed.
    PS: bias pots are going bad in these amps quite often. It is advisable to install fresh bias pots. Then you can test if the pots are working properly, WITHOUT the tubes in the sockets.
  20. ampmadscientist
    12,675
    6,566
    Left Coast
    Follow the tests, write down all the readings. Report all the readings to the forum.
    Don't skip the tests, do them all.
    1. Install fresh batteries into meter.
    Set meter on 200 ohms.
    Touch the red and black probes together.
    What is the reading?
    Prove that the meter is working. Report the readings to the forum.
    2. Take the tubes out of the amp.
    Turn the power on, and set the standby for "warm-up." Do not turn the standby to "operate."
    Set meter to 500 DC volts.
    Black probe: connect to metal chassis.
    Red probe: connect to pin 5 of output socket.
    Measure pin 5 of all output sockets. Write down the readings as: "pin 5 warm-up."
    What are the DC readings of all pin 5, output tube sockets?
    3. Turn standby to "operate."
    Measure pin 5 of all output sockets. Write down the readings as: "pin 5 operate."
    Report your DC readings.
    You should have: 8 DC readings to report. 2X DC pin 5 readings for each socket.
