Jcm 2000 Tsl 100 Fuse Replacement Inquiry
Discussion in 'The Workbench' started by uglycustoomer, Jun 11, 2018.
  1. uglycustoomer
    uglycustoomer New Member
    Feb 20, 2013
    9
    Hello - one of my fuses blew and I replaced it with a MDL 2A -250v Fuse. Once I turned the amp on and played for a few minutes, I noticed that the volume was very low. The amp felt extremely hot and one of the tubes blew.
    The back of the amp by the fuse box says it can take the following,
    T2A - 230v
    T4A - 120v
    I live in the U.S.
    Can someone recommend which fuses would be OK for my amp? Having a really tough time finding an exact match.
    Thanks!
  2. mickeydg5
    21,246
    8,921
    Being in the U.S. your utility supply voltage is 120VAC so the amplifier mains fuse should be time delay/slow blow 4A.
    If you are also blowing power tubes then the amplifier will need more attention as well as new tubes and bias check.
    CraigP and Jethro Rocker like this.
  3. Jethro Rocker
    6,957
    6,670
    Also a fuse rated at 250V is fine as long as it's a 4 amp. Don't look for a 120v T4 fuse if they're hard to find.
    As stated above, the extra heat and blown fuse may indicate a dead tube so don't just change the fuse and continue.
  4. uglycustoomer
    Feb 20, 2013
    9
    Great. Thanks for the feedback!
  5. GT08
    GT08 Active Member
    May 31, 2016
    288
    180
    The voltage written on a fuse is just the Maximum operating voltage for that fuse, so 250v is fine.
    The important thing is current. At 120v mains supply the fuse must be 4 amp.
    VERY IMPORTANT.....all mains fuses must be special SLOW BLOW fuses, available on line no problem.
    If a correct value fuse blows you have a problem with the amp/valves.
    Rock n' roll
  6. The Dose of Harmony
    The Dose of Harmony Well-Known Member
    Nov 21, 2014
    356
    268
    how its it going with your amp? I havent heard you about your bias before and after the fuse , you might need to check your amp in a deeper way! if its or was running hot
  7. ampmadscientist
    12,758
    6,635
    Left Coast
    Troubleshooting required.
    1. Take the output tubes out. Replace the fuse.
    Turn the amp power on, but leave standby off.
    3. Measure DC voltage at pin 5 of output tube socket (note this voltage). This should be a negative DC voltage.
    If there is no negative voltage on pin 5, the bias has failed.
    If the bias failed you cannot operate the amp.
    4. Continue to measure voltage at Pin 5 of output tube socket.
    Turn the standby on.
    Note the difference in pin 5 DC voltage between standby off, and standby on.
    5. If the negative voltage Pin 5 changes to a positive voltage, (or changes substantially) when you turn standby on,
    then you probably have a defective circuit board.
    If you have a defect board, you cannot operate the amp till the problem is repaired.
    6. Allow the amp to run for 1 hour or more, and monitor the pin 5 bias voltage. If this bias voltage drifts when standby is turned on, then the board is probably defective.
    If this defect board condition exists in your amp, then the output tubes will be destroyed, and the fuse will blow.
    7. No
    do not replace output tubes until you have tested this......
    the bias voltage must be steady... :nono::nono::nono:
    otherwise ---- kiss the new tubes goodbye.
    royslead and The Dose of Harmony like this.
  8. The Dose of Harmony
    Nov 21, 2014
    356
    268
    you are the best one! short ,clear and to the point !!! love it!
  9. ampmadscientist
    12,758
    6,635
    Left Coast
    This is what happened the last time bias drifted.
    The Dose of Harmony likes this.
  10. royslead
    royslead Well-Known Member
    Jan 19, 2011
    1,672
    1,038
    Wisconsin
    VERY helpful info, Amp' !
  11. 6StringStewie
    6StringStewie Active Member
    Jun 10, 2017
    235
    165
    In the US, you will need the following fuses:
    1 Mains Fuse - 4 amp slow blow 6x30mm
    1 HT Fuse - 1 amp slow blow 5x20mm
    4 Heater Fuses - 6.3 amp slow blow 5x20mm (located inside the chassis)
    For reference, these are the fuses I use. Some are ceramic and some are glass. Either are fine.
  12. 6StringStewie
    Jun 10, 2017
    235
    165
    Your tube blowing is not from the wrong size fuse. It was either a tube that went bad or you encountered the bias drift problem associated with these amps. Where are you located? If you are close, I could stop by and take a look at your amp.
    Stewart
