Is this setup a truly stereo sound?
Discussion in 'Marshall Amps' started by marshalltsl, Oct 15, 2019.
  1. Gutch220
    Gutch220 Well-Known Member
    Feb 19, 2018
    673
    467
    NJ
    do you know if somebody makes an analog photo-sensor Univibe pedal with stereo outputs, tap tempo, and expression pedal jack for speed? I can't find one with all three (just two)
  2. zachman
    zachman Well-Known Member
    Feb 8, 2011
    5,906
    5,124
    Tone Mountain
    No. That's typically used in between the guitar and the amp's input, so splitting the signal to stereo-- later on down the signal chain is preferable, and usually POST amp for stereo delays, reverbs, chorus, and the like. (For a old school tape delay or analog delay not so much, as they were typically used in front of the amp).
    My Eventide H8000FW will do what you're talking about, and the new H9000 will too, but neither is a pedal or analog
  3. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,626
    2,545
    A simple stereo chorus just puts a slight delay on the "wet output" and it sounds good imo, then throwing it slightly in and out of tune makes it even sweater specially when clean with chords.
    zachman and Mitchell Pearrow like this.
  4. SmokeyDopey
    Mar 9, 2011
    11,123
    6,598
    Argentina
    Can you be more specific? Because that also describes dual mono.
  5. zachman
    Feb 8, 2011
    5,906
    5,124
    Tone Mountain
    Sort of... but not necessarily-- re: being fed from separate inputs
    Sure, here are a couple of examples of dual mono rigs:
    Ex. 1) A slave setup one type of 'series' dual mono use, and in that configuration Amp A is fed w/ the guitar, and sends the signal from amp A to amp B. Amp A's preamp section is routed to amp B's power amp section (Typically), and amp B is putting out a blend of amp A and B, while amp A is as though stock.
    Ex. 2) Guitar plugs into an A/B splitter, which feeds the input of Two mono combos, each with their own separate fx. (Also a dual mono application, but 'parallel'-- not 'series' like ex. 1)
    OR
    Ex. 3) one acoustic amp and one electric guitar amp w/ A/B splitter (also a type of parallel dual mono configuration)
  6. SmokeyDopey
    Mar 9, 2011
    11,123
    6,598
    Argentina
    Yes, but some people split the signal, process the signal differently (hence, separate inputs) and it would be considered dual mono. I don't disagree with it being dual mono, but I would say the audio processing is a dual mono setup. But If I stand in front of that rig, I would say it has a stereo effect. I can understand though why someone would argue it isn't "true stereo".
    Thanks
    Mitchell Pearrow and marshalltsl like this.
  7. zachman
    Feb 8, 2011
    5,906
    5,124
    Tone Mountain
    Sure, lots of ways to do things. ;)
    Ex 1. Slave setup BUT also Stereo... Guitar plugs into amp A. Amp 'A' FX Loop send to stereo delay. Stereo delay Left output to Amp 'A's' fx loop return, Stereo delay's Right output to amp B's FX Loop return. voila
    Ex 2. Same as above but not using the fx loop send returns like above w/ 2 heads or combos-- rather into a stereo power amp from the L/R outputs of the delay and you can have a W/D/W setup or if using the LOAD down trick, using the attenuator you can eliminate the middle dry center image and have stereo.
    :cheers:
    Mitchell Pearrow and SmokeyDopey like this.
  8. SmokeyDopey
    Mar 9, 2011
    11,123
    6,598
    Argentina
    True, but I never said the guitar signal automatically becomes a stereo signal. It was an attempt to reaffirm the notion that what would determine something being stereo is the way it is captured. "Captured" being where it is positioned in the stereo field.
    But that example (the dry DI signal slightly panned) is from a mixing standpoint and what constitutes something being a stereo mix. I can understand why one would have to look at it a bit differently when describing strictly a guitar rig.
    marshalltsl, Dogs of Doom and zachman like this.
  9. MonstersOfTheMidway
    May 1, 2008
    4,832
    2,285
    I can't really add anything to the discussion other than to say I learned a lot. Thanks to all who contributed.
  10. StingRay85
    StingRay85 Active Member
    Aug 18, 2019
    102
    60
    Or you can daisy chain a few Marshalls and turn all knobs to 10, and be mainly creative with your hands?
  11. BftGibson
    BftGibson Well-Known Member
    May 28, 2018
    1,205
    2,901
    ster·e·o
    /ˈsterēō/
    Learn to pronounce
    noun
    noun: stereo
    1.
    sound that is directed through two or more speakers so that it seems to surround the listener and to come from more than one source; stereophonic sound
  12. zachman
    Feb 8, 2011
    5,906
    5,124
    Tone Mountain
    If you're trying to achieve stereo, that won't work either-- regardless of creativity or proficiency in your hands. ;)
    :cheers:
  13. zachman
    Feb 8, 2011
    5,906
    5,124
    Tone Mountain
    Learn to read carefully. ;)
    Stereo" redirects here. For other uses, see Stereo (disambiguation).
    "Stereophonic" redirects here. For the similarly named band, see Stereophonics.
    Not to be confused with Duophonic sound.
    Time difference in a stereophonic recording of a car going past.
    Stereophonic sound or, more commonly, stereo, is a method of sound reproduction that creates an illusion of multi-directional audible perspective. This is usually achieved by using two or more independent audio channels through a configuration of two or more loudspeakers (or stereo headphones) in such a way as to create the impression of sound heard from various directions, as in natural hearing.[1] Thus the term "stereophonic" applies to so-called "quadraphonic" and "surround-sound" systems as well as the more common two-channel, two-speaker systems. It is often contrasted with monophonic, or "mono" sound, where audio is heard as coming from one position, often ahead in the sound field (analogous to a visual field). Stereo sound has been in common use since the 1970s in entertainment systems such as broadcast radio, TV, recorded music, internet, computer audio, and cinema.
  14. SmokeyDopey
    Mar 9, 2011
    11,123
    6,598
    Argentina
    I think this is the best example of how something wouldn't be considered stereo when explaining strictly a guitar rig:
    I'll see if I can replicate that example in my DAW, like an A/B test of the differences and why it wouldn't be considered "stereo" (again, specifically speaking in a guitar rig design/setup).
    zachman likes this.
  15. zachman
    Feb 8, 2011
    5,906
    5,124
    Tone Mountain
    Use 2 mics, each on it's own channel, while recording your tracks-- and pan each L/R.
    Listen with headphones:
  16. mickeydg5
    22,634
    9,948
    His example is stereo simply because each channel affects the the signal separately producing a different sound on LEFT channel and RIGHT channel. The incoming signal is mono but gets panned from one device/effect to the other. The separation of signal and space make it stereo.
  17. SmokeyDopey
    Mar 9, 2011
    11,123
    6,598
    Argentina
    I agree with you Mickey, which is why I emphasize that I'm strictly speaking of guitar rig design, not in a mix context.
    The confusion is what you just described technically can be speaking of a dual mono setup too.
  18. zachman
    Feb 8, 2011
    5,906
    5,124
    Tone Mountain
    Actually, my example is not mono because I was recording a W/D/W rig (Mono middle DRY cabinet in parallel to a stereo L/R fx section with L/R cabinets w/ 3 mics-- each on it's own channel, recording the corresponding speaker cabinet, recording with the panning effects happening live in real time.
  19. BftGibson
    May 28, 2018
    1,205
    2,901
    worked on the concept for about last 2 weeks.Fussing over mono & stereo during tracking. Come to realize the stereo came to basically mean R & L. In the interest of a mix..how you view the music being produced.,,how it come to the litener Kick-bass;vocals down middle ..then positioning things naturally around the mix to sound real in those parameter...headphones being not so tru to represent..but using our left & right ears as the 2 receivers of the sound...how darn natural can i make everything...in the end..wish would of just looked that definition up...anything bouncing around is manipulation of time & distance with panning back n forth...cause the natural sound is coming L & R
  20. SmokeyDopey
    Mar 9, 2011
    11,123
    6,598
    Argentina
    My best attempt to articulate this:
    When speaking strictly of a guitar rig design, what one would state something being true stereo is both channels are interacting with each other. The simple definition of stereo is hearing 2 different things from 2 channels (channels being L/R speakers), but for a guitar rig to be considered stereo there has to be an interaction or relationship with those 2 channels. This sounds a bit broad because this technically can also be a dual mono setup. The best example I can think of now is that ping pong delay example. Having 2 different delays with different times can probably yield something similar, but it doesn't have the same ping pong effect. It isn't a stereo delay unit feeding 2 channels with a certain pattern/relationship, they're just 2 delays setup with certain times. Yes, it has like a stereo effect, and in a mix context that is undoubtedly "stereo", but in a guitar rig design framework, the latter example would be a dual mono setup.
    marshalltsl, Mr. Natural and zachman like this.
