Is This A Real El34 Amp Release From Marshall At Namm?
Discussion in 'Marshall Amps' started by pleximaster, Jan 3, 2018.
  1. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,482
    1,526
    Will Marshall release something really new at the NAMM show this year. They have this on there twitter account. Or is it another fridge...
    plexi
    https://twitter.com/marshallamps/status/942696472004497411
    grainman likes this.
  2. slide222
    slide222 Well-Known Member
    Apr 5, 2013
    2,528
    1,614
    cambridgeshire uk
    its the release of the 20 watt heads -no el84 , no this time el34 , a tube with some bite
  3. pleximaster
    Feb 6, 2012
    1,482
    1,526
    It looks like at least two EL34 tube/valves and that would traditionally seem to be a 50 watt if it a traditional push-pull marshall amp.
    Slide222 do you have any more info of these 20 watt heads.
    best plexi
  4. el_bastardo
    el_bastardo Well-Known Member
    Apr 26, 2017
    3,723
    3,501
    It's less than two weeks away. What do you need to know about it right now that can't wait 12 days?
  5. MarshallDog
    Nov 28, 2010
    12,566
    12,215
    Taintville
    Pleximaster, if you find out anything more please let us know...thanks!
    pleximaster likes this.
  6. pleximaster
    Feb 6, 2012
    1,482
    1,526
    Haha! True! I guess I am just curiously inpatient! and previously disappointed...
    Plexi
    el_bastardo likes this.
  7. el_bastardo
    Apr 26, 2017
    3,723
    3,501
    I'm with ya there buddy!
  8. Buzzard
    Buzzard Well-Known Member
    Sep 14, 2016
    921
    1,070
    I can see it now marshall dosen't come out with what everyone want's,and I picture a ship going down with rats scurrying and running for safety lol. Not at all comparing dissatisfied marshall lovers as rats but curious what builders/companies will guy's go to for what they want?
  9. colchar
    colchar Well-Known Member
    1,223
    727
    The Great White North
    They will still buy Marshalls, just older ones.
    jcm800gridlock and JCMDOUG like this.
  10. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    602
    450
    There are lots of ways to run tubes at lower power. Look at Fender's Princeton Reverb and Deluxe Reverb -- both have two 6V6's push/pull Class AB fixed bias pentode operation, but one is 12 watts and the other is 20.
    Just lowering plate voltage can drop a pair of EL34's down to 20 watts.
    Besides being a little more club/home friendly, a 20 watt dual EL34 amp should be lower priced because it can use smaller power & output transformers.
    It's rare to see EL34's or 6L6's in the 20 watt range because those tubes are more expensive than EL84's and 6V6's. And it's arguable whether big tubes run at lower voltages sound the same as they do at higher voltages.
    But there are a lot of consumers who want big bottles in a lower watt format. The clamor for maximum watts per dollar ended a long time ago, so a 20 watt EL34 amp makes sense now.
    jdto, solarburnDSL50 and neikeel like this.
  11. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,588
    1,675
    Södertälje, Sweden
    ....tube Hifi with built in streaming services. ..
    ...dear dog...I hope not...
    J
  12. neikeel
    3,653
    2,076
    20w and x2 EL34s probably has them in cathode bias. They can sound pretty good like that.
    I would be interested to what novel features they incorporate.
    Mayhem13 and solarburnDSL50 like this.
  13. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    8,248
    5,120
    ITS A REFRIGERATOR ... tube driven of coarse.
  14. Kinkless Tetrode
    Aug 17, 2017
    973
    1,164
    The 2525 runs two EL34s in push pull at 20 watts. The plate voltage is about 280 volts if I recall correctly. They sound and respond pretty much the same as at 460 volts and 50 watts.
    The Soldano Mini SLO runs two 5881s at about 325 volts.
    The 2525 and the 25 watt Soldano destroy similar 20 watt amps running 6V6s or EL84s in my experience.
  15. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    5,020
    5,058
    Montreal
    Best comment from that Marshall teaser:
    "Notice how the gif fades to black, I bet it's their utility company shutting their power off due to slow sales"
    Trelwheen likes this.
  16. pedecamp
    13,629
    9,928
    Don't forget the SL5 has a single EL34 for power.
  17. PU239
    PU239 Well-Known Member
    Sep 3, 2015
    886
    1,083
    Puget Sound
    For years Marshall has had requests for a low watt plexi.
    I am familiar with a prototype they have had for almost four years now that is a modern take on the 2061x.
    Paul Gilbert can be seen with it in a couple of videos, the video just shows the chassis, not in a head box. Paul loved the amp.
    Not sure if Marshall finally decided to bring it into production, but that would make the most sense.
    There was also a 1 watt prototype that had been made and shelved.
  18. JCMDOUG
    JCMDOUG Well-Known Member
    Mar 1, 2015
    445
    338
    where its cold
    The Bogner Alchemist has a 20 watt mode with two 5881s/6L6 they call the brown sound. looking at the Schematics The mess with the voltage from the power supply to get 20 watts.
  19. JCMDOUG
    Mar 1, 2015
    445
    338
    where its cold
    Here is what they did.
    Holzar88 likes this.
  20. Holzar88
    Holzar88 New Member
    Dec 1, 2016
    18
    22
    FWIW, I've got an Alchemist, and the difference between 40-watt mode and 20-watt mode is pretty negligible. A bit less volume, but, really, not that much.
    Not that it matters. Just thought I'd chime in on that issue.
    Looking forward to seeing what's cooking with this new release.
