Is this a mod?
Discussion in 'The Workbench' started by LPMarshall hack, Feb 16, 2020.
  1. NewReligion
    Nov 17, 2009
    11,108
    7,994
    Paradise
    Perhaps I am misunderstanding you. This is not my thread I simply posted exactly what I did to a JCM900-2500 series with a video and the exact changes I made to it.
    As to the OP and the inverted master volume as it appears at VR2, I have no idea.
    No I did not & I still do not recognize the original mod on the opening thread.
    Of course I remember all of my mods even those that take 14 hours to achieve. They are all archived in schematic and layout format.
    David
    LPMarshall hack likes this.
  2. LPMarshall hack
    Nov 18, 2009
    10,704
    9,800
    San Diego, CA
    Hi Dave
    so what you’re saying is, the mod done to my amp, it’s not the same as what you did with your sons 2500? Am I understanding you correct?
  3. NewReligion
    Nov 17, 2009
    11,108
    7,994
    Paradise
    Correct.
    1.) I do not know the values that were used on your R5 & R8. Should have been R5 3.3k / R8 1.5k
    2.) D2 appears to be the stock single 1N4007 instead of a set of 1N4733
    3.) R4 is 220k instead of 330k
    4.) R7 appears to be 100k instead of 330k
    David
  4. MickeyJ
    MickeyJ Well-Known Member
    Nov 11, 2019
    1,062
    585
    Hi David, I wasn't directing your post at you, I was directing it at the person who took credit for your mod.
    Your're not the type of person who does that shit.
    I knew who designed the mod from the start, see I read the link before I posted it.
    Regards
    Mickey.
    NewReligion likes this.
  5. NewReligion
    Nov 17, 2009
    11,108
    7,994
    Paradise
    Try changing out D2.
    David
  6. MickeyJ
    Nov 11, 2019
    1,062
    585
    What he's saying you beer guzzling amp pirate is that the mod was done on a jcm900 2500 with possibly different resistor placement to yours.
    I think you'll find in relation to r5, it's the same.
    different types of jcm900, different boards, different printing.
    It's david mod on another jcm900.
  7. LPMarshall hack
    Nov 18, 2009
    10,704
    9,800
    San Diego, CA
    Oh I’m not looking to mod anything David. I just posted this thread because I discovered the odd looking pot while cleaning the pots. Was just curious if it was a mod, so I asked here.
    turns out my amp had a couple of mods that I didn’t know about! Glad I posted this thread. Thanks guys!
  8. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    5,859
    6,561
    Montreal
    10-4. Over & out.
    BP
  9. RickyLee
    May 22, 2010
    9,944
    3,376
    Riverside CA U.S.A.
    Man, I have had my MK III stored away for awhile. I really want to hear it now . . . . thinking I need to start selling some of these amps I have man lol.
    It was cool to look at the schem for these now that I know a bit more these days.
    Be careful as there are two versions it seems with some different component callout locations between the two.
    I can not remember which pot is the Sensitivity? Is it VR1 pot? If you are able to put it at 0 and sound still comes through, then by the looks of the schem it must be VR1.
    I am trippin on the Presence circuit in this amp - very different for sure. Just adds a .22uF cathode bypass cap to 3rd stage.
    https://drtube.com/schematics/marshall/cd0109-iss4.pdf
    https://drtube.com/schematics/marshall/cd0109-iss9.pdf
  10. Gunner64
    Nov 16, 2013
    6,022
    7,678
    Midwest, USA
    Geebus, How many g damn amps do you actually have Ricky?
  11. RickyLee
    May 22, 2010
    9,944
    3,376
    Riverside CA U.S.A.
    I do need to get a count some day lol.
    Though the steady gigging has all but slowed down, I am holding onto the guitar amps in hopes that this will finally be the year when I get my recording studio built. Then, this massive collection will start making practical sense again. I will then be able to start seeing which amps will be the ideal recording situation.
    I was considering starting up an amp leasing/rental business as well.
    :D
    I am already thinking I need to offload the generic speaker cabs that I truly do not need. The one that I might want to save the speakers from is the old Randall 4X12 slant that is loaded with 8 ohm G12-65's. I rarely see 8 ohm 65's out there.
  12. LPMarshall hack
    Nov 18, 2009
    10,704
    9,800
    San Diego, CA
    Hey ampmad...I think you only commented on the one mod that creates some more lower frequencies.
    but you also mentioned the board has been modded in several other places. I dont believe you mentioned what the other mods were. Can you elaborate where the other mods are on the board and what they do?
    Thanks in advance.
  13. 6550
    6550 Member
    Jan 11, 2010
    94
    66
    Mine is the same as the other pots..
  14. Jaska9
    Jaska9 New Member
    Jan 17, 2020
    Hi, hard to say just by the picture, is this a mod. I mean, is the pot function different than original one. But it's not an original pot.
    The original broken pot has been replaced with this bigger one, so it had to be wired with separate wires, because it doesn't fit straight into printed circuit holes.
    Regards, Jaska
    Is this normal? If not, any ideas?
    I tried to load a pic but it says it’s too large. Story of my life![/QUOTE]
  15. Tobaccosun
    Tobaccosun New Member
    Sep 29, 2017
    2
    It’s normal. It’s a clipper circuit similar to what you find in Friedman be-100 (sat switch) but in this case it’s placed in the middle of the preamp instead of after it and before tone stack. It uses clipping diodes for solid state clipping. If turned up too much it will sound like total crap, it would’ve been much better placed later in the circuit.
  16. LPMarshall hack
    Nov 18, 2009
    10,704
    9,800
    San Diego, CA
    Not sure if you read the thread, but most seem to think it’s just a replacement for the stock pot...as if someone didn’t have a stock pot to put in there.
    also pics of other mkiii’s dont have this kind of pot.
