Is It Possible To Put A Tube Amp In A Marshall Mg Combo?
Discussion in 'Marshall Amps' started by JacksonCharvelAddict, Jun 26, 2017.
  1. JacksonCharvelAddict
    Mar 4, 2016
    1,642
    1,636
    I have an old Marshall MG50RCD that my grandmother bought me back when I graduated from high school. I have not played it in a long time but I can't bring myself to part with it. I always loved the clean channel and I discovered at band volume that the clean channel has a very pleasing breakup to it that I found way better than the drive channel or any pedals I ran into it. I am guessing the worst part of this thing is the speaker. I am wondering if any of you guys have gutted old MGs and put JCM800 circuits in there?
  2. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    1,260
    2,065
    Replace the speaker - easier, cheaper and faster. Or go to a 1x12 or 2x12 closed [my preference] or open back cab. Converting to a tube amp would require new pretty much everything including [I'm guessing here] trannys. Blast the sh*t out of that clean channel as you save up $$ [if you want to go down THAT deep dark rabbit hole] for a tube amp.
    Russ
    JacksonCharvelAddict and Kiko like this.
  3. Kiko
    Kiko Active Member
    Jul 16, 2015
    341
    225
    +100 on what Geeze said. Economics and practically isn't there, just enjoy the mg.
  4. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    8,248
    5,121
    Waste of time & $$$
  5. JacksonCharvelAddict
    Mar 4, 2016
    1,642
    1,636
    Thanks guys. I figured the only way it would be worth it is if there was a tube amp that had the same dimensions.
  6. Gunner64
    Nov 16, 2013
    5,460
    6,597
    Midwest, USA
    Not an mg..but I have gutted an AVT150H and built an 800 2204 clone in it. Shit canned the old chassis..faceplates and modified a mojo 800 chassis and plates to fit..cost about 600 or so before tubes..classictone trannys/ choke..turned out great. But not any resemblance to what it started out as.
  7. marshallmellowed
    Jun 26, 2009
    3,335
    3,613
    If all you care about is keeping the combo box, then yeah, anything with the right dimensions could work. If you're talking about adding tube circuitry to the MG chassis, I wouldn't even attempt it.
  8. JacksonCharvelAddict
    Mar 4, 2016
    1,642
    1,636
    I assumed that nothing in there would be worth re-using.
  9. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    1,150
    890
    Saginaw MI
    Nothing in there can can be used for a tube amp...maybe the jacks and pots...but that's nickel-dime stuff.
  10. JacksonCharvelAddict
    Mar 4, 2016
    1,642
    1,636
    I figured the knobs would be about all that is usable. Sounds like I just need to keep an eye out for a tube amp that will fit.
  11. Gunner64
    Nov 16, 2013
    5,460
    6,597
    Midwest, USA
    Id build an 18w tmb in that sucker...mod the 18w chassis and plates to fit..
    myself80 likes this.
  12. myself80
    myself80 Active Member
    Apr 3, 2015
    269
    41
    Nassau, Long Island
    Hello!
    I built an 18 watt 6v6 amp with a 2204 pre amp in an old model # 5010 master lead 30. I love the amp!. However, the most work was in modifying the chassis for the tube sockets, filter cap holes, standby switch, 2nd input, etc, etc.
    I also swapped the original g12-75s speaker for a g12H(55).
    If you enjoy metal working like me, it will be fun.
    I would say go for it!
    Cheers!
    For info, here is the link to my build:
    http://www.marshallforum.com/threads/new-18-watt-2204-combo-build.86368/
  13. JacksonCharvelAddict
    Mar 4, 2016
    1,642
    1,636
    This is exactly what I was thinking. Thanks a lot for the link!
  14. Gunner64
    Nov 16, 2013
    5,460
    6,597
    Midwest, USA
    I had to do some work on the mojo 800 chassis and plates to make them fit the avt headshell, but I think it turned out great..sounds incredible too. Very rewarding if you choose to do it. And you could keep the guts out of your combo if you ever decide you want to change it back. CAM00281.jpg
