Is it me or two amps sound weird ?
Discussion in 'Marshall Amps' started by Kelia, Feb 9, 2020.
  1. Kelia
    Kelia Well-Known Member
    Feb 26, 2018
    585
    461
    Hi guys ,........was trying two amps at the same time an hour ago ,
    one is a 1996 2555SL and the other's a 1988 2205 ,..both plugged into a 4x12.
    First ,....I tried them with my Radial ABY and switched the polarity to 180 degree and there's
    a latency in the sound that I don't get or like even though I tweaked the amps to sound almost the same bass-treble-mid-gain wise. Could it be the difference in speaker cables or different speakers in the cabs that creates the out of focus non calibrated kind of sound or it's an illusion because of sound diffusion not spread evenly ?
    Also,......because of Bob Gjika's video below saying that our signal should never ever pass trough a Radial ABY junk Chinese circuitry because it kills the signal and we should instead use an ABY cable and lift the ground on one amp ,...I tried it also and still I find the sound awkward.
    To make a long story short,...I think I prefer one amp with two cabs !
    What are your thoughts ?
    Here's the Bob Gjika vid,
    tce63 likes this.
  2. herbvis
    herbvis Active Member
    Jul 8, 2010
    152
    150
    I just recently ran my modded 2203 clone and my 50 watt orgin combo together using my boss super chorus a and b outputs. Worked well, no issues.
  3. Mitchell Pearrow
    9,161
    14,164
    I don’t have a radial switcher, but I did try running 2 amps with a ABY box , and got hum and other noises I didn’t like, but with my MXR10 band eq, no problem whatsoever, same thing with the Vox tone lab, and I am always running 2 amps in dual mono fashion, plus a third amp by using the FX send to instrument in.
    No problems .
    Cheers Mitch
  4. Lance Chambers
    Jun 23, 2019
    972
    1,376
    The Land That Time Forgot
    I use my vintage Guyatone Stereo Chorus. :shred:
  5. RickyLee
    May 22, 2010
    9,726
    3,219
    Riverside CA U.S.A.
    I can not remember if the 2205 and Jubilee have the same phasing? As in, they might be out of phase when you try running them together. You will usually not encounter this when playing two same amp models together. But . . . . If you run two DSL 100's together, one on Green channel other on Red channel, you will then be out of phase. That is because Green has 4 stages and Red has 5 stages. AC audio signal polarity is flipped/reversed 180 degrees every time it passes through a plate/anode follower stage. If it is a cathode follower stage, the polarity remains the same.
  6. Kelia
    Feb 26, 2018
    585
    461
    Bang !!......This is exactly what I'm hearing !!.......Phasing !.........small percentage but it's there .
    So if I would use two Jubilees,.......it would be more focused or in phase ....Thanks Ricky
  7. RickyLee
    May 22, 2010
    9,726
    3,219
    Riverside CA U.S.A.
    Should sound good with two Jubes. You can try inserting a pedal that flips the phase on one of the 2205 or Jube amps, then that will verify it. Some compressor pedals, maybe phase 90 or dirt pedals might reverse the phase.
    I thought those fancy Radial ABY things had that option?
  8. Kelia
    Feb 26, 2018
    585
    461
    Yes it does and I hear a difference when I flip it to 180 degree but I still hear something off ,
    what I hear is one amp being faster than the other on the trigger if that makes any sense or like two circles not aligned on top of each other .
    I'll do more test tomorrow and see.
  9. SmokeyDopey
    Mar 9, 2011
    11,215
    6,751
    Argentina
    I tried one of those Radial ABY boxes, and I wouldn't recommend it.
    It does sound like a phase issue. That 180 switch may get it closer to 100% in phase, but it sounds like it still may not be perfectly in phase.
  10. DragonCrestPC
    DragonCrestPC Member
    Aug 28, 2019
    45
    58
    Have you tried adjusting the drag on the aby? I use to use one and always had to max it out for it to sound right ( still sucked some low end )
  11. Trelwheen
    Trelwheen Well-Known Member
    Nov 18, 2017
    1,643
    2,498
    Texas
    At one time I had a slick little stereo rig with a Pro Junior and a Laney LC15, using a Radial Switchbone. I noticed a huge difference when I would switch them in and out of phase....In phase they sounded like one amp in the middle. Out of phase they sounded like two amps far apart. Sounded good both ways, just different. I would play rhythm in phase and leads out of phase.
    Kelia and Mitchell Pearrow like this.
  12. Kelia
    Feb 26, 2018
    585
    461
    I'll try it but I think the Radial will end up in the drawer till mushroom grow on it !..haha!
  13. Kelia
    Feb 26, 2018
    585
    461
    Yeah I hear you ,..even in phase it's still awkward .
  14. mickeydg5
    23,703
    10,730
    What most do not know is that there is more that affects signal phase than the number of tubes. Capacitors and inductors as well as the quantity and arrangement also affect signal phase.
    So a signal phase switching capable device may not always do the trick.
  15. Kelia
    Feb 26, 2018
    585
    461
    Thanks Mickey for your input !...........think it sounds better one amp two cabs vs 2205/2555 setup,
    I'm definitely hearing something wrong.
    Mitchell Pearrow and mickeydg5 like this.
  16. mickeydg5
    23,703
    10,730
    @Kelia
    You are welcome.
    The built in reverb circuits of the 2205/2210 play a part due to reverb driver and pan transformers along with associated capacitors.
    Kinkless Tetrode likes this.
  17. Kelia
    Feb 26, 2018
    585
    461
    Thanks !.........got it !......probably why I hear a latency between the two !
  18. El Gringo
    El Gringo Well-Known Member
    Jul 24, 2015
    1,570
    1,442
    Shakedown Street
    Well , I am here to tell you I am running 2 -2555X into 2 -2551AV cabs using the Radial ABY pedal and the sound is massive and huge . Bob Gilka is dead wrong about the Radial ABY pedal. I don't even have to use the phase feature on the Radial ABY pedal as both amps sound identical . I have footswitched between the amps to compare one to the other and there are identical . The Radial ABY pedal does a good job .
  19. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    612
    464
    When I've run two or more amps together, I've never tried to make them sound similar. A dark amp and a bright amp, a clean amp and a dirty amp, different effects.
    That's kind of the point of the A/B function, but it also works for the Y function. Two amps together that sound different gives depth and sounds you can't get from either by itself.
    If I just wanted more fullness or more volume, I'd either use one head with more cabs, or two identical rigs. I can well imagine that using two similar but not identical amps set pretty much the same way could sound weird.
    I had a Radial Bigshot A/B/Y. Worked fine except for the isolation transformer. Never actually needed to use the iso, but when I experimented with it I discovered it was a major tone sucker. Putting any sort of buffered pedal in front of the Bigshot clears that up, though.
  20. Kelia
    Feb 26, 2018
    585
    461
    I don't understand how you don't need to switch the phase ?......two amps should be out of phase ,..no ?
