Interesting Looking Kit - Mojotone Studio 1
Discussion in 'Building the Classics' started by pedecamp, Dec 31, 2017.
  1. pedecamp
    11,745
    6,690
    Has anybody seen this? Originally I was interested in the JVM1 but the clean channel was too clean to get any grit. This Mojotone is a 1 watt kit with 2 foot switchable channels, the clean channel can be dialed to get some grit in your tone and the dirty channel can be dialed any way you want. Price isn't bad either.
    http://www.mojotone.com/kits/MojotoneAmpKits_x/Mojotone-Studio-1-Kit
  2. Crunchifyable
    Crunchifyable Well-Known Member
    Oct 28, 2011
    662
    337
    Georgialina, USA
    Not bad. I'm always doubtful of 12__7s as a power tube but I've never had one with a true tube phase inverter.
    I think a single ended el84 probably sounds better, but that's my best hunch.
    I think mojo is too expensive but everything they sell commands a premium.
    If you like the JVM, that's a pretty easy circuit to copy, believe it or not.
    All it is is 3 triodes cascaded, and a switch between each triode to allow for 1, 2, or 3 triodes of gain. They route the tone stacks separately.
    The clean channel on the JVM is based on a fender blackface, so that's probably why you don't like it.
    Personally I'm going the complete custom route. I'm starting off with a plexi / 2204 hybrid, and can easily change it to a bright plexi + OWM. With a channel switch or separate inputs.
  3. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    9,416
    6,630
    Taintville
    Not familiar with this amp but sounds great and I can say MojoTone has top notch QC and great customer service. I am awaiting a Marshall 1X12 Blues Breaker clone combo cab from them. I would venture to guess anything they offer is top quality.
  4. stickyfinger
    stickyfinger Active Member
    Nov 11, 2010
    464
    142
    The shemati I have shows 3 gain stages with a cathode follower straight into to the 12bh7 power tube. Its a original circuit. Clean has it own circuit.
    It would be easy to change the circuit to soemthing more traditional but not showing a PI circuit for this type of valve made me decide to pass. I didn't want to do the research/engineering.
    Still very cheap and should be a killer practace amp if anyone is thinking about it
    Crunchifyable likes this.
  5. Crunchifyable
    Oct 28, 2011
    662
    337
    Georgialina, USA
    That's a shame about the PI. I learn a lot by reenginneering, but I guess the point of a kit is to build it by the book, simple and easy.
    My HT-5 is a letdown and the lack of a traditional phase inverter may be part of that. For all the hate the class 5 got, that single little bottle sounded pretty big.
    It's probably a cool amp to build. But with a different power amp.
  6. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,345
    1,131
    Södertälje, Sweden
    It's just self split output. Same principle as a regular long tailed pair by applied on the output tubes. . In such application it'll be slightly unsymetrical when driven into clipping thou.
    But on the other hand, with a "clean" channel, I'd assume they don't intend for the "power amp" to saturate and clip.
    ..it looks cool with that vintage marshall style head box thou.....
    J
  7. pedecamp
    11,745
    6,690
    The Marshall style head box is cool, I thought the power section was odd I never even heard of a 12BH7 tube but yeah since its a low volume 1 watt amp the power section is definitely not a big deal. My problem is I'm not a builder, a $550 kit plus pay someone to build it starts adding up unfortunately. To bad they don't sell them ready built for $550, I really like this amp I'd consider getting one.
  8. MarshallDog
    Nov 28, 2010
    9,416
    6,630
    Taintville
    Maybe someone on this forum can build it for you for a low price???
    pedecamp likes this.
  9. pedecamp
    11,745
    6,690
    Thats a nice idea! They do say its a 5hr build, should be easy for an enthusiast.
  10. Crunchifyable
    Oct 28, 2011
    662
    337
    Georgialina, USA
    My advice is to take your time and build your own if you want something that's not really on the market, or overpriced (vintage Marshalls, Fenders, supros, etc). Or just want to have a mod platform (with a turret board you can change things as often as you want.
    A number of amps use 12BH7s, 12au7s, as power tubes. Personally I am a little skeptical of them but hey...I own a Blackstar HT-5 that uses that amp and the power amp is a weak spot of the amp (but could also be the tiny OT).
    The power amp colors the sound...and I think I get better results with EL84 or a big bottle. But I'm a low volume, master volume, headroom kinda person. HT-5 is a thin amp...incapable of any real bass.
    Honestly $550 is a lot for this amp and a lot of that is a fancy chassis and output transformer, etc. For that price you can buy a brand new assembled low watt amp. But hey I get my parts from ebay, home depot, Mouser, and tayda.
    I'm building my first amp and it's a little hairy at times...but if you stare at a schematic or layout long enough you will get it. I think wiring a turret board is easier than wiring a guitar...the turret board actually holds everything in place.
    Tube amps are simple. Innovation, quite rare. Todays amps are not far removed from Leo Fenders...we just have added more switches, more controls, and voiced it for mids.
  11. stringer
    stringer New Member
    Mar 15, 2016
    25
    21
    Jacksonville,ALabama
    20180321_095135.jpg Here's my studio one build.
  12. pedecamp
    11,745
    6,690
    So tell us about it.
    Unfortunately I've moved on from this, Marshall recently put out a DSL1 head for $299 ready to go if I decide I need a small tube amp.
    FutureProf88 and stickyfinger like this.
  13. stringer
    stringer New Member
    Mar 15, 2016
    25
    21
    Honestly
    Played with it through 4x12 cabinet loaded with 25 watt greenbacks
    Sounds ok. Nothing to go out and build one .
    I'e got other amps I prefer to use.
    I just wanted to build another amp kit .
  14. stringer
    stringer New Member
    Mar 15, 2016
    25
    21
    Some pic of the guts..
    Please excuse the wiring color scheme..and sloppy build. 20171127_041535.jpg 20171127_041544.jpg 20171127_041554.jpg
  15. jensvonbustenskjol
    Feb 5, 2012
    593
    199
    Norway
    Just bought myself a Fargen mini plex. I'm sorry mister fargen but I'm bringing my screwdriver and oscilloscope to the party... It's a wicked amp! I guts to know its secrets.... Muhahahaha
  16. stringer
    stringer New Member
    Mar 15, 2016
    25
    21
    Show us the guts pics
    neikeel likes this.
  17. printer
    printer Member
    Sep 30, 2017
    86
    91
    I would want a phase inverter also. I would use a Mosfet split phase inverter with it. But then again, I like pentodes rather than a triode output.
    Here is an example of using a IRF820 as the PI. It gives you no gain as the Cathodyne circuit but it does not have the odd behaviors of the Cathodyne when overloaded. The circuit is just a Tweed inspired cathode biased amp that is reminiscent of the Fender Harvard/Vibrolux/Princeton without the tremolo and fixed bias.
  18. proxy
    proxy Active Member
    Sep 2, 2010
    451
    126
    How do you like MiniPlex?
    Is it the latest version?
  19. jensvonbustenskjol
    Feb 5, 2012
    593
    199
    Norway
    It's not the latest,but it's the mkII at least. Sound wise I love it. Great overhead.
    I miss footswitch for changing style, and also send return loop could be nice. But it's retro all the way.
    I like it a lot. I'm not sure it's worth retail price. I got a great used deal.
