Input Grid Resistor. Mod, Or Keep Stock? '81 2203
Discussion in 'The Workbench' started by JakeAC5253, Nov 30, 2016.
  1. JakeAC5253
    JakeAC5253 Member
    Jun 25, 2013
    60
    9
    I've heard some people recommend to lower the value of the input grid resistor on my 1981 JCM800 2203 from 68k to 1k and that this increases gain slightly and lowers noise at higher gain levels. I'm normally a guitar straight to amp guy, but I do like running some ODs (OD808, OD820, Modded SD-1), distortions (Japan HM-2) or fuzzes (Fuzz Face, Modded Big Muff) from time to time.
    Should I fuck with the value or not? I have researched a bunch of mods for the amp already, and most when you look deep enough, you find reasons to leave it stock.
  2. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,714
    1,943
    Södertälje, Sweden
    Might add a tiny bit of zizle in the highest highs but also risk adding in radio interference. I'd leave it. Or replace with same value metalfilm resistor if you worry about noise.
    Remember, people usually remove the bright cap to reduce highs. This would do the opposite.
    J
    JakeAC5253 likes this.
  3. Jazz P Bass
    Jazz P Bass Active Member
    May 19, 2015
    229
    30
    Wernersville, PA
    Keep in mind that it isn't simply a 68K resistor.
    It's a circuit.
    There is also a 1Meg resistor to ground.
    That's refered to as a voltage divider.
    Personally, as the rest of the amps circuits rely on that first stage, I wouldn't mess with it.
    There is a reason most all amp input circuits use that 68K/ 1 Meg divider circuit.
    It works very well.
    wakjob and JakeAC5253 like this.
  4. johan.b
    Feb 21, 2015
    1,714
    1,943
    Södertälje, Sweden
    on the 2203/4 the 1M comes before the grid resistor, so only the miller effect plays in.
    even if it came after, it's a near 1/20 ratio. you loose less than a db...had it been 20/1, it would have been significant
    J
  5. ampmadscientist
    18,092
    12,134
    No, you really don't want to change that: maybe 33K at the least.
    All that happens is that it overloads the input, resulting in muddy-ness, especially w/ effects pedals.
    No, it does not "increase gain," at all. It does increase sensitivity, but too much is bad.
    Gain is limited by the power supply voltage.
    But what you can do: is use higher gain (selected) preamp tubes, and this makes a big improvement.
    (high gain tubes are actually high sensitivity, it's not the gain that is making a difference)
    "gain" and "sensitivity" are 2 different things...
    What you want is: increase sensitivity...the "gain" is not the actual issue.
    The amp has a fixed amount of gain...and you cannot increase that. (V2 preamp is a compressor stage, which limits the gain)
    No matter how much signal goes into V2....it cannot produce more gain...only more compression. The output of V2 is always LESS than the input.
    BUT what you can do is increase sensitivity...which is actually what you DO want.
    Marshall Plexi: sensitivity = 10 mv
    It takes 10 mv of input signal, to drive the amp to full 100W output.
    Marshall 2203: sensitivity = 5 mv.
    It takes 5 mv of input signal to drive the amp to full 100W output.
    So you see the difference?
    2203 is twice as sensitive as Plexi. But both amps are 100 watt.
    The difference is sensitivity....not gain.
  6. stickyfinger
    Nov 11, 2010
    633
    264
    Its a grid stopper. The first one is the noisiest resistor in the amp. Making it smaller is always a good idea if Radio interference doesn't come in to play. Amps have had improvements since the typical vintage value of 68k. A bunch of newer amps (Vox/Fender/ect) use replace the 68k with a 10k/100p to ground divider. This gets ruffly the same frequency shaved off while allowing the resistor to be much smaller/less noisy.
  7. ampmadscientist
    18,092
    12,134
    I think resistor too small makes the amp sound (too hot) overloaded...I am frequently making the resistor larger, not smaller.
    But true, first resistor does contribute to noise the most, that is undeniable.
  8. neikeel
    4,237
    2,687
    I agree with AMS on this, I find 33k works well (which is effectively what you get in a 4-holer with a pair of 68k in parallel) for not being too big, giving optimum sensitivity, effective as a grid stopper for noise and giving the pups a loading that works too.
  9. JakeAC5253
    JakeAC5253 Member
    Jun 25, 2013
    60
    9
    I figured as much. I had reservations about it, pretty much everything mentioned here, just wasn't sure if it was a common modification for these amps or not as this is my first Marshall. I really have no issue with the sound of the amp currently. I am going to be adding a 3 position switchable gain mod to it in the next days as soon as parts arrive, and somebody recommended the grid stopper mod because apparently in modded gain ranges, noise can become an issue. I suppose I'll leave it stock (fantastic amp, no doubt worthy of its legacy) or put another 68k in parallel if noise really is very noticeable at higher gain levels.
  10. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,551
    1,665
    I know this is an old thread but I resently saw my third old Jtm45 with 47k gridstoppers instead of 68k
    I have previously always though divination from the 68k like 47k and 56k we’re replacements. But the h looked good
    Anyone else seen Marshall used off values in plexis, non 68k grid stoppers???
  11. stickyfinger
    Nov 11, 2010
    633
    264
    Nope but seen 82k replace 100k plate resistors.
    I'm sure they used another value when they ran out undeniably
    pleximaster likes this.
  12. FourT6and2
    FourT6and2 Well-Known Member
    Dec 3, 2010
    489
    258
    I use 33K input grid stopper on V1. Any Marshall that had multiple inputs/channels with 68K input resistors were running two in parallel when using only one input. That's 34K. So when I build single-channel amps, I just use 33K.
