If you love your guitars avoid Schaller Straplocks
Discussion in 'The Tone Zone' started by GuitarIV, Aug 14, 2019.
  1. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    6,890
    4,390
    North
    I never had a problem either in several years.
    Micky likes this.
  2. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,171
    1,111
    THIS works.
    No weaknesses except it's more of a "leave it on" solution vs the quick detach ones...and the strap button itself can still work itself loose, as on other systems
    SkyMonkey likes this.
  3. mk2 steve
    mk2 steve Well-Known Member
    May 21, 2012
    1,029
    634
    Schallers are very reliable. Dab of loctite on the nut as mentioned and they’ll never come off. I’ve been using the same set for about 12 years now through many, many gigs and they’ve never failed. Hardware on a guitar will need maintenance at some point, straplocks are no different. Check that the nut is tight.
    I’ve seen Dunlop’s fail, including on a friends Les Paul that resulted in a broken headstock. Personally dislike their system and avoid them at all costs.
    I also like the DiMarzio cliplock straps. I’ve got them on a couple of guitars and they work well.
    tallcoolone and Micky like this.
  4. MemphisMarshallMan
    MemphisMarshallMan Active Member
    Nov 8, 2014
    232
    181
    Properly installed Schallers will not fail you.
    That word "properly" is the key word.
    Frodebro, fat_lenny, Micky and 2 others like this.
  5. johnfv
    johnfv Well-Known Member
    Sep 29, 2010
    5,624
    4,188
    Austin TX
    I too have used Schaller locks exclusively for decades and have never had a problem. You have to make sure the nut is TIGHT when you install on the strap and like *any* nut that is in a high vibration environment, you need to use thread lock.
    Micky likes this.
  6. mk2 steve
    May 21, 2012
    1,029
    634
    In my opinion checking the nut on a set of Schallers is no different to checking the input jack nut on any guitar is done up tight, as they are the same design, and work loose over time.
    fat_lenny and Micky like this.
  7. Neil Skene
    Neil Skene Well-Known Member
    Oct 3, 2011
    777
    1,153
    Australia
    Ive used the Schallers for ever but always on leather. Hold the cup with pliers while you use a spanner to tighten the nut.
    only problem I have had is lending my strat to someone (almost 30 years ago) who wanted to use their own strap. he stood there reefing on my strap for a few minutes before he realised they lock on. Dick head stuffed the thread in the wood and I had to put a longer screw in it.
    MarshallDog and Micky like this.
  8. GuitarIV
    GuitarIV Well-Known Member
    Apr 26, 2017
    844
    1,557
    Well guys, I get it. I should retighten the straplocks every once in a while. Still annoying, because the Dunlops have been absolutely maintenance free and never failed me. If I manage to find the washer and the bit that tightens it I will give it another try. They went missing :rolleyes:
    Neil Skene and MarshallDog like this.
  9. pedecamp
    13,337
    9,393
    Check out a small company called Well Hung strap locks out of Canada, you can find him on Reverb, he makes very affordable leather strap locks, I have them on all my guitars. I never liked any of the commercial brands I could never fit any of my thick leather straps on them.
    GuitarIV likes this.
  10. MarshallDog
    Nov 28, 2010
    12,098
    11,279
    Taintville
    So you are now well hung, haaa :D
    GuitarIV and pedecamp like this.
  11. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    720
    652
    I use diamond shape button style because I never trust them either. But if you want them to work.... Magpul. (Some will know.)
  12. Sir Don
    Sir Don Well-Known Member
    Aug 9, 2009
    1,270
    667
    Adelaide, South Australia
    DiMarzio clip locks for me.
  13. johnfv
    Sep 29, 2010
    5,624
    4,188
    Austin TX
    If you tighten it well the first time and put thread lock on it you will never have to touch it again.
    Frodebro, GuitarIV and Micky like this.
  14. GuitarIV
    Apr 26, 2017
    844
    1,557
    Been intrigued by them, might have to check some out.
    As said, I'll give the Schallers another try. Just seriously need to find the washer and the nut they dissapeared into a black hole similarly like guitar picks do
    O.o
  15. neikeel
    3,511
    1,950
    Schallers for me, on my gigging guitars, same on my son's basses and guitars, no problems here.
    Micky likes this.
  16. Jeff Hudson
    Jeff Hudson Active Member
    Jul 10, 2016
    228
    202
    Levelland Texas
    Had the same problem a long time ago (90's), started making the hole in the guitar strap bigger to fit on the strap lock with out the strap curling. Haven't had one come loose since.
  17. dptone5
    dptone5 Well-Known Member
    Jan 31, 2010
    5,186
    3,835
    Pennsylvania
    I have equipped all my guitars with Dunlop Strap Locks after I dinged my Jackson Soloist. Never had an issue with any in many years.
  18. Micky
    Apr 29, 2010
    20,379
    16,554
    Vermont
    Schaller's new S-Locks are awesome!
  19. john hammond
    Mar 5, 2019
    952
    442
    i had a schaller strap lock crack around the casing, around the bit that grabs the machined head that stays on the guitar.
    guitar fell off me, caught it.
    if you take a look around that area ( the bit on the strap, the casing,) its cast and very thin.
    what i do now is brutal, i just drive a (longer than stock) screw straight through the strap and into the wood of the guitar.
    straps stay attached to guitars, perfect.
    i use tow strap material made for towing cars, nice and pliable, very strong. Just cut to length and burn edges.
  20. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,626
    2,545
    Well a little finish wear is a whole lot better to me then a dent or crack in the finish when the guitar hits the floor.
    I still like em and they lock any strap button so the guitar needs no mods.
    Micky likes this.
