I want to add 1 ohm resistor for ease of biasing
Discussion in 'The Workbench' started by Rotorcraft230, Apr 7, 2020.
  1. Rotorcraft230
    Rotorcraft230 Well-Known Member Premium Member
    Aug 15, 2019
    413
    279
    Brazoria County Texas
    CCC6EEF9-F896-413D-8A72-A87CAF82059B.jpeg CA8CD3D1-3739-42F1-A16B-D8B5DDBABC37.jpeg I would like to add a 1 ohm resistor between pin 1 and 8 then pin 1 to ground for ease of biasing. The amp is a 1959 first reissue from 1988 S/N beginning in “W”. It does not have one and was wondering if there are any affects to the amp tonaly or anything else?
    Thanks Mark
  2. Matthews Guitars
    1,799
    2,378
    No change to the tone will occur. Personally, if that were my amp, I'd upgrade to ceramic octal sockets.
    Ken Underwood likes this.
  3. marco_giampa23
    marco_giampa23 Active Member
    Feb 11, 2020
    245
    221
    STRAYA
    I have been told there are no downsides or tonal changes, havnt gotten round to doing this on my jubilee but some others on the forum will have some more info for you
  4. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,009
    711
  5. Rotorcraft230
    Aug 15, 2019
    413
    279
    Chris-in-LA likes this.
  6. Rotorcraft230
    Aug 15, 2019
    413
    279
    9361822F-A5A7-4DDF-AB8B-74FF9BEE0803.jpeg I have this. One plug is the socket and the other plug is the pin(they are NOT connected inside the socket). It is pin 8 and it allowed me to measure actual mA. It works well but it takes forever to do one tube at a time. Just looking for something easier.
    And from a resale perspective would the added 1 Ohm resistors affect the value?
    It’s all stock except for a 1 wire mod that someone did which I removed. The circuit board appears to have never been removed until I did to replace a wire properly.
  7. RobS
    RobS Active Member
    Apr 19, 2009
    954
    221
    Melbourne - Australia
  8. neikeel
    4,212
    2,669
    As per our JTM45 conversation
    use 1 watt 1R 1% resistors.
    Snip the wire that goes to ground on the output socket. Do not disturb the link between 1&8. Then solder your 1R resistors between the ground lug and pins 1&8 on each socket.
    Done.
    mixn4him likes this.
  9. Im247frogs
    Im247frogs Well-Known Member
    Jan 31, 2012
    610
    749
    Brooklyn, Joey!
    It's a pretty handy feature and as long as it's clean and looks factory I don't think anyone ie future buyer is going to freak out about it.
  10. Rotorcraft230
    Aug 15, 2019
    413
    279
    Thanks Neikeel, if I do it I’ll do it like that. I can’t imagine it changes anything but making biasing easier. What type of resistor?
    I can make it look very nice, it’s not my amp it’s my Sons and he has been adamant about leaving it stock.
  11. neikeel
    4,212
    2,669
    I would suggest 1w 1R flame proof metal oxide, but make sure that they are 1% tolerance.
    Flame proof because if a tube shorts it will typically act as a fuse.
  12. South Park
    2,186
    1,787
    I would get the tube socket to bias the amp .
  13. Rotorcraft230
    Aug 15, 2019
    413
    279
    Ok thanks
    Im weighing my options.
  14. anitoli
    anitoli Well-Known Member
    7,472
    8,809
    You could use a scope......................................:D
  15. neikeel
    4,212
    2,669
    you are a naughty man!
  16. American Viking
    American Viking Well-Known Member
    Jan 9, 2009
    4,063
    1,217
    RICHMOND, VIRGINIA
    You can add the 1ohm resistor between pins 1 and 8 and you won't have to desolder anything. You would just have to clip the solid wire between the two pins.
    I use a desoldering vacuum and rework it all and position the 1 ohm resistor in a way where i can get my meter leads to it easily. Quick and dirty works too. You've got two unused holes in those pins ready to take the new resistor.
    I've done this to all of my amps whenever I have to bias new tubes. Makes the process way easier.
  17. neikeel
    4,212
    2,669
    See the JTM45 build post where this method was discussed.
    Cathode to G3 and then via 1R to ground is probably a more purist approach vs cathode to 1R to ground with G3 link but it really does not make any difference - what works for you.
    Either way you are going to need to cut a wire and solder a resistor in on each socket so no big deal.
  18. Rotorcraft230
    Aug 15, 2019
    413
    279
    thanks fellas, both are easy ways to add the resistor for convince of biasing. I’m not very happy with what I’m seeing as far as the mA. We bought the amp online and it’s a great amp but I think the seller must have put his stash of miss matched tubes in.
  19. Rotorcraft230
    Aug 15, 2019
    413
    279
    I have them together as best I can in pairs. V4,V5. Average 23 mA
    V6,V7. Average 23.43mA
    I have biased the highest tube V5 to 35mA and the pot is all the way up.
    Should I have more adjustment in the pot than that. 25X.7=17.5. 17.5/460=38
  20. neikeel
    4,212
    2,669
    I think that is the right way to go with the halves of the OT roughly in balance. It is a guitar amp not a hifi and that mismatch should not bother you at all, and these settings are at idle so you don't really know what each tube is doing when you are hammering it with signal.
    Ideally you want a bit more range on bias adjustment but that will involve generating a little more negative voltage on pin 5 and you will need to either play at piggy backing resistors over the existing 'stop' resistor or pull the pcb to sub a different value. What is in there now 47k or 56k are typical (the resistor in series with the bias pot)?
