I OWN A MARSHALL FULL STACK
Discussion in 'Marshall Amps' started by Exotic, Sep 11, 2019.
  1. Exotic
    Exotic Active Member
    Sep 3, 2018
    348
    158
    HI i got some pretty cool news for myself ,i finally got a slant cab for my half stack ,so now the 3 pieces are this :
    1.jcm 800 2210 100 watt head(signed by tommy chong )
    2.4x12 1960bv cab
    3.a jcm 900 4x12 slant cab
    so no more mismatches right? cabs get set to mono 16 ohm and the head goes to 8 ohm and that's it ? how about the 2 different types of speakers? the vintage straight cab has those vintage speakers in it and the jcm 900 has the g12t-75 . both cabs have wheels and the wheels on the slant should line up fine with the wheel wells ,or dugouts or wheel recepticles whatever they r called ? it's a little beat up but i can glue tape and paint the tolex back together like i did with the vintage cab . oh the best part the final slant cab cost $152.00. anyone know where the g12t-75's were made? china or england?
  2. netlocal
    netlocal Well-Known Member
    Jan 16, 2012
    372
    789
    California
    Nice rig.:hbang: 900 era should be made in the UK.
    Mr. Natural and Mitchell Pearrow like this.
  3. marshalltsl
    marshalltsl Well-Known Member
    Apr 6, 2012
    361
    402
    Catalonia
    Enjoy It! Seeing your pics I think all it's made in England. You connect It correct, both cabs at 16Ohms to the amp 8 ohms speakers outputs.
  4. Madfinger
    Madfinger Well-Known Member
    Feb 16, 2019
    327
    470
    Straya
  5. Force235
    Force235 Well-Known Member
    Nov 15, 2012
    952
    452
    MA
    Full stack 6100 Limited Edition here...
  6. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    283
    267
    Good news indeed!
    Lotsa pic's but not seeing signature through the weed lol
    Correct, Full stack using both cabs with the 100w heads impedance switch set to 8ohm.
    Is your vintage straight cab with the vintage speakers wired 16ohm 100w? - Treat both cabs as 100w.
    The stereo switch on the JCM 900 cab uses 150 a side at 8ohm.
    Yes, The JCM 900 1960 Lead cab set to MONO switches the cab to 16ohm 300w.
    100w 16ohm + 300w 16ohm = 200w 8ohm capacity
    Rock those nice Gibson's! Happy cranking & congrats on your score!
    Mr. Natural and netlocal like this.
  7. Kinkless Tetrode
    Aug 17, 2017
    1,027
    1,233
    ^^ Actually the BV cab should have the G12 Vintage speakers rated at 70 watts each. 8 * 70 = 560 watts power handling.
    Mr. Natural likes this.
  8. Exotic
    Sep 3, 2018
    348
    158
    they both have original wiring ,is the impression i'm under ,been using the straight fine for a couple months ,seller says the slant is all original . sorry to dissapoint? the guitars aren't gibsons? but only copies ,1970's ibanez . sig foto down below .he signed it upside down bending over the amp ,so the story goes . thanks guys for the help ,and the funny vid . can we see a photo of the 6100 limited edition?
    hey nice music !
  9. Micky
    Apr 29, 2010
    20,499
    16,794
    Vermont
    That's cute. I don't see them stacked tho...
    Mr. Natural and BanditPanda like this.
  10. Exotic
    Sep 3, 2018
    348
    158
    stacked foto coming soon ,i have to pick it up and get someone to help me stack it in my room or the garage : (
    so the jcm 900 = 300 watts ,the 1960bv = 280 watts ,will both play nice together?
    netlocal and Mitchell Pearrow like this.
  11. Matthews Guitars
    1,129
    1,474
    They'll work together just fine. One may be a LITTLE bit louder than the other, depending on speaker sensitivity.
    If the speakers in one cab are rated 100 dB sensitivity (100 dB @ 1 watt @ 1 meter) and the ones in the other cab are rated at 97 dB sensitivity,
    then at any volume level that one will be 3 dB quieter.
    As for patching the tolex, if you can lay your hands on a small piece, you can splice a patch to the cabinet fairly easily. Cut out a piece that's a little bigger than the area to be patched. Staple it down over the area to be patched, so it doesn't move. Use a fresh razor blade to cut through both the new and the old layers at the same time, and cut the shape of the patch you want. When you've gone all around it, pull the staples, remove the new tolex, peel out the damaged tolex, clean the wood, position and glue down the patch in its new home. It should be an exact fit if you kept the razor straight and vertical in the cut all around. If you darken the wood with a black permanent marker, around the edge, before you glue in the patch, it'll make any open seam invisible at any distance.
  12. Exotic
    Sep 3, 2018
    348
    158
    wow that was great repair clinic !thanks !
  13. junk notes
    Dec 10, 2018
    283
    267
    ha, The sig!
    nah, not disappointing, they're great! (missed it glancing at the thumbnail)
    okay cool! Then the 1960bv = 280 watts as Kinkless Tetrode posted. You are in great shape!
    Yes & yes ;-)
    Don't get hurt. Wait for help, and let's see it after the official stack!
  14. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    5,313
    5,612
    Montreal
    We need to see a pic of the full stack please.
    Sorry just saw the the full stack photo has already been requested.
    Understand that it is not because we do not believe you but rather that it gets us off !!!:fever:
    BP
    Mr. Natural, scozz, Trelwheen and 4 others like this.
  15. Exotic
    Sep 3, 2018
    348
    158
    that's pretty funny ,i wanna see it stacked too trust me .
    did you notice the joint underlining his name?
    seller of the head told me he (tommy)requested specifically a jcm 800 for his comedy show and the owner of the club knew the seller and he(the seller) lent it to him and he(tommy) signed it after the show .
  16. Lance Chambers
    Jun 23, 2019
    973
    1,381
    The Land That Time Forgot
    Great tip!:agreed:
    If you run your marker over the cut edges of the Tolex it will also hide the white fibers of the cut and keep it out of sight.
  17. MarshallDog
    Nov 28, 2010
    12,902
    12,634
    Taintville
    Congrats! Now there goes your hearing lol!
  18. Lance Chambers
    Jun 23, 2019
    973
    1,381
    What did you say?
  19. Mitchell Pearrow
    9,163
    14,173
    :funny: :cheers:
  20. Trelwheen
    Trelwheen Well-Known Member
    Nov 18, 2017
    1,647
    2,502
    Texas
    I heard you got a Marshall stack
    Cork them ears and brace your back
    Crank them knobs until they crack
    Give the crowd a heart attack
    :headbanger:
